Old 10-12-2008, 05:36 AM   #1
fr8tshaker's Avatar
2006 34' Classic
Sioux Falls , South Dakota
Adding Tank Heaters
JC will add tank heaters to my unit for about $1800.
Is it worth the $$ since we FT?
Will it keep the tanks from freezing while we are rolling down the road?
What about the water lines?
Is there a way to add some type of heat strips to the internal water lines to prevent freezing?
We do boondock in the winter. usually in OK, AR, and TX.
Thanks for the help in advance. 'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 10-12-2008, 07:55 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Seems to me it would be a lot cheaper to leave the furnace on. I have done this in the winter when travelling and you have a nice warm trailer when you stop for a break.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-12-2008, 08:06 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
The short answer is no. Tank heaters like this are 120V and cannot operate off the tow vehicle. Furnace ducts usually route above the floor near the pipes and work to keep those spaces warmer. You may want to trace your plumbing system. Some areas might require leaving a lower cabinet door open to allow heat to get in. Shower mixer valves in outside walls are particularly susceptible to freeze damage. Do you have copper pipes? Those are more sensitive.
You're going to have to measure inside temps to get a sense of what you've got to do. Place a thermometer inside the trailer near plumbing at floor level. Set the furnace on maybe 40-50 degrees and drive for an hour or two at a given outside temperature. Then go see what the thermometer says. I'd suspect you'll need very little heat when it's above 20 degrees F outside.
I found out the hard way not to set the thermostat to 'comfortable' levels. I set it at 60F while traveling 6 hours in 15 degree weather. Used the better part of a 30# propane cylinder too.
The stinger is "your results may vary." The consequences of a freeze-up are pretty costly.
5 meter Langford Nahanni
Old 10-12-2008, 08:50 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
When it comes to freezing the tanks are the least of your worries. If you are traveling the motion alone will keep the tanks from freezing long after the pipes have frozen.
A tank heater would be useful if you are parked for a long period of time and the trailer heater just is not putting enough heat into basement.
2004 Excursion 4x4
Old 10-12-2008, 10:14 AM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Hey Michelle,
Gee, you guys really are SNOWBIRDS!
I've spent a few winters in TX, Dallas, Huston area, and it has never gotten cold enough for my pipes to freeze.
A bit of water running, flushing the pipes with HOT water from the hot water heater helps keep the cold water pipes from freezing( they run side to side for the most part)
It would have to get really really cold, for an extended period of time, to freeze the tanks and pipes.
Michael
ArtStream is offline   Reply With Quote
Old 10-12-2008, 01:30 PM   #6
fr8tshaker's Avatar
2006 34' Classic
Hi Michael,
I just sent you an email.
I think DH is over reacting to this financial crisis. He thinks we ought to get the AS ready in case we have to go
further north to follow work. I can't imagine people doing without chicken!I am starting to feel as though I am
getting ready for " Grapes of Wrath". He also thinks that we should utilize the solar system (If you recall, your posts
convinced him that was a GREAT idea) as much as possible. He thinks if we can keep the tanks and lines warm
with thru the use of tank heaters and some type of water line heater tape , we won't have to buy as much
propane. 'shaker
2010 Ford F250 PSD
Hensley Arrow Hitch
Old 10-12-2008, 02:26 PM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Be more worried about your water lines and drain traps. This is where the water is not moving. It is more likely to freeze. You can get 12VDC tank heaters but that will drain your batteries quickly. You will need 120VAC to recharge the batteries quickly.
Most of the heat ducts run with the water lines. Check to make sure they still do. You can put RV anti freeze down the drains wich will keep the black and grep from freezing. Turn the pump off, relieve the pressure on the water lines. That way if they do freeze they are lees likely to burst and if they do burst you will only have a small mess.
I leave my furnace on 55 when I travel in below freezing conditions.
Michelle
Michelle TAC MT-0
Sarah, Snowball
Old 10-17-2008, 08:15 AM   #8
fr8tshaker's Avatar
2006 34' Classic
After reading all the responses, I think there is nothing to gain by adding tank heaters.
Guess I have to let DH know that he is no Henry Fonda... if he was I would have a little gold plated naked man to play with. LOL!
Thaks for the input. 'shaker
2010 Ford F250 PSD
Hensley Arrow Hitch
Adding more water tank capacity rpcarlson Plumbing - Systems & Fixtures 8 09-21-2008 01:14 PM
Tank Heaters -vs- Antifreeze TitusLivy Winter Living 21 09-10-2007 05:07 PM
Adding tank in 1962 Tradewind kipperdavid Waste Systems, Tanks & Totes 2 05-13-2007 09:42 PM
Adding a Gray Tank to my '72 Sovereign mello mike Waste Systems, Tanks & Totes 6 08-11-2004 03:50 PM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 07:11 PM
