Old 08-12-2017, 04:26 PM   #1
stephenb's Avatar
2011 25' FB Flying Cloud
Hutchinson , Kansas
Adding 1" female fitting to freshwater tank
Hello Airstream Freaks,
I recently had a leak in my 2011 25fb freshwater tank so I dropped the tank and had a crack in the fitting of my suction side.
I ordered a new tank from an airstream dealer in Oklahoma and had it drop shipped to me in Kansas. I got the part number from the 2011 airstream parts list online.
Well today I got everything organized and began the process of re installing and realized that there was no fitting to re install my water level monitor. Ugh!
Trying to find a remedy but now know this is either going to involve a lengthy discussion with my oklahoma a/s dealer and cost for shipping back, not to mention the time.
Was wondering if anybody has any experience spin welding. I got on vintage airstream supply's website and they have fittings and installation tools to add the proper fitting. youtube even has some how to videos.
Just wondering what others have done.
thanks
Steve
ID:	292043   Click image for larger version
ID:	292045   Click image for larger version
stephenb is offline   Reply With Quote
Old 08-12-2017, 04:54 PM   #2
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Look up plastic welders in your area or call custom plastic shops for a referral of a plastic welder.
sheriff1 is online now   Reply With Quote
Old 08-12-2017, 09:16 PM   #3
stephenb's Avatar
Hutchinson , Kansas
Should have mentioned that in my first post. I'd have to ship it some where. Nobody in Kansas does this kind of work.
Old 08-12-2017, 10:35 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Metairie , Louisiana
Maybe it's time to upgrade to external tank sensors, that just get glued to the side of the tank, no fitting required.
WBCCI #1105
TAC LA-4
I don't have an anger management problem. I manage to remember exactly what everyone has done to make me angry!
Old 08-12-2017, 11:37 PM   #5
2007 22' International CCD
As in seelevel systems vice the useless Micropulse stuff Airstream insisted on installing for years.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 08-13-2017, 06:49 AM   #6
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
We've used SeeLevel II sensors for since early summer, after having them installed with a bigger renovation. Wonderful product. The drag for you would be having to do the other tanks, as access to the black and grey tanks might be tricky. Nobody in Wichita that does this type of stuff? Not sure if there's any aviation application for this type of trade. Good luck!!!
DaveMc is offline   Reply With Quote
Old 08-13-2017, 05:26 PM   #7
2013 25' FB Flying Cloud
NRH , Texas
I've been there!
Last weekend I was in your shoes. Same exact break at the fitting. I cut out the old fitting the the fix cost less than $10 with a PVC fitting from big box store (sprinkler isle) and the magic...JB Weld Marine putty. Sets in 25 mins and re-assembly in an hour.
No leaks! I'll be keeping a role of this putty in the trailer in case of plumbing emergency!
Good luck. Glad to assist if needed.
Steve
RedSandS is offline   Reply With Quote
Old 08-13-2017, 07:37 PM   #8
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I can't believe there aren't any plastics supply dealers/welders in Kansas.
bibbs is offline   Reply With Quote
Old 08-15-2017, 05:09 AM   #9
stephenb's Avatar
Hutchinson , Kansas
Work it out. The sensor just needs to be sensing water pressure at a low spot in the system. I t'd of the drain lol be and reinstalled the tank. Everything works great again.
ID:	292271   Click image for larger version
Old 08-15-2017, 05:41 AM   #10
Not THAT is outside-the-box thinking! Literally!
WBCCI #1105
TAC LA-4
Old 08-15-2017, 11:08 AM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
When I installed a greywater tank in my '71 Cayo, I purchased an ABS tank specifically so that I could cement the bulkhead fittings in place. It is much easier than dealing with polyethylene.
Spin welding is no small thing. There are jigs available but they are expensive, and are usually built around a big router. It is a process you would want to practice a number of times on scrap before using it on a valuable tank.
In your situation, I would use a clamp-on bulkhead fitting, like this:
http://pvcpipesupplies.com/1-pvc-bul...as1010ces.html
Old 08-16-2017, 10:44 AM   #12
stephenb's Avatar
Hutchinson , Kansas
I thought of using that but there was no way possible to put the inside piece in position to tighten them together. And yeah the spin welding thing looked easy but jigs were pricey and it's a one shot deal. You mess it up and tank is ruined. I thought about the marine jb weld but to many folks that have done it say over time it will work. I'm glad the job is done and now ITS OFF TO CAMPING!!!! ��!!!!
Adding "Cap" to avoid lights "dancing/flickering" trekerboy Electrical - Systems, Generators, Batteries & Solar 13 09-21-2016 02:25 PM
filling freshwater from shore fitting Greg1410 Fresh Water Systems 15 03-12-2016 10:53 PM
Single Female Needs Advice-please! GunnerCoast Land Yacht/Legacy Motorhomes 18 07-16-2012 04:21 PM
