Old 11-25-2015, 08:54 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Accumulator
I installed one of those shurflo accumulators to go with my PAR water pump. I can't tell much difference other than the water pump will run for about 3-4 secs, then pause for about a second, and then run for 3-4 more seconds, etc. Before it would cycle on and off about every second or two. Is this all it's suppose to do? I guess I was expecting more water flow without the pump running.
KYAirstream is offline   Reply With Quote
Old 11-25-2015, 09:10 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It's greatest use is to take up thermal expansion in the water system and prevent leaks and possibly damage to connections. It also functions as a shock absorber smoothing the operation of the system.
To have a large supply of water without the pump running frequently you would need a much larger accumulator. The pump would then run less but much longer. I've thought about it but our little Shuflo works well enough.
Doug and Cheryl
Old 11-25-2015, 09:38 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Have you adjusted the air pressure in the accumulator?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-25-2015, 09:42 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
An accumulator is merely a reservoir with an air bladder that can be compressed when water pressure is applied and expand when water pressure is released. When your system is operating at a relatively high pressure you have a very fast flow of water through an open faucet, and as soon as you shut off the faucet, the pressure builds up in the plumbing. In extreme cases, you can experience "water hammer" which is a noise carried through rigid plumbing as the pressure is instantly applied. The air bladder in an accumulator allows the pressure to be applied more gradually and quietly.
An accumulator will make little difference in how your pump runs, and in fact it will be more useful when you're hooked up to a relatively high-pressure municipal system, not when you're pumping from your fresh tank.
On a related issue, an accumulator is more useful if you have rigid plumbing— PVC or copper— than if you have the more flexible PEX.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-25-2015, 10:01 PM   #5
2007 22' International CCD
If you don't use the standard Atwood water heater, like we do, an accumulator is kinda needed for a tankless water heater. The pump short cycles and makes a lot more noise when the accumulator or an air bubble in the Atwood is not there. The nice thing about the accumulator tank is that you don't lose the trapped air bubble.
KE4GNK/AE
Old 11-25-2015, 11:31 PM   #6
2011 27 FB International
Vancouver , British Columbia
I find it most useful simply to prevent leaks from pressure changes during cold weather, which I was experiencing in various locations until I installed the accumulator. No leaks since.
mixedpuppy is offline   Reply With Quote
Old 11-26-2015, 10:47 AM   #7
1998 30' Excella 1000
Livingston , Texas
Oh, and be careful of trying to get longer flow by upping the pressure charge. If I recall correctly, I think it was supposed to be 20 psi and I went to 30 psi, and busted the membrane.
If the pump cycling is really bothering you, and you have the space, there are somewhat larger (2 gallon) accumulators available.
Siegmann is offline   Reply With Quote
Old 11-26-2015, 10:59 AM   #8
dkottum's Avatar
I think the Shurflo comes preloaded to 30 psi and that has worked well for us. Yes I can see how the membrane could break raising it too high, really no need to increase it that we have seen.
Doug and Cheryl
Old 11-26-2015, 11:08 AM   #9
Livingston , Texas
You got me thinking about that so I checked. Your 30 psi is fine, according to Shurflo.
http://legacy.shurflo.com/pages/Food.../911-378-P.pdf
Maybe I had gone to 40 psi. Can't recall.
Old 11-26-2015, 11:11 AM   #10
dkottum's Avatar
Thanks for checking, I wasn't certain but good to know.
Doug and Cheryl
Old 11-26-2015, 02:27 PM   #11
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
There is a stedfast limit as to how much I can accumulate.....
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-27-2015, 08:31 PM   #12
My understanding from the manual is that the accumulator is installed right after the pump, which is a line separate from the city supply (in my case there is a check valve. ). So are you saying it should go in the supply line that both the pump and city supply share?
Old 11-27-2015, 08:34 PM   #13
Did you hear it bust when you applied too many PSI, or did it just stop operating as it did before?
Old 11-27-2015, 08:38 PM   #14
It will work better that way, I think.
WBCCI #1105
TAC LA-4
What size Accumulator? '07 Bambi 19' Phantom Fresh Water Systems 10 08-21-2007 08:56 AM
New Water Pump or Accumulator Al - K4GLU Water Heaters, Filters & Pumps 4 08-15-2007 09:45 AM
Why no accumulator? Roger S Fresh Water Systems 29 08-09-2007 06:30 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
