Old 11-27-2015, 09:46 PM   #15
1998 30' Excella 1000
Livingston , Texas
Originally Posted by KYAirstream View Post
Did you hear it bust when you applied too many PSI, or did it just stop operating as it did before?
No sound. Probably just a tear. When I removed the air hose, a little water came out of the air inlet fitting. Clearly got water on the wrong side of the bladder. Oh, and it did stop operating as it had before.
Siegmann is offline   Reply With Quote
Old 01-01-2016, 07:30 PM   #16
Oak Harbor , wa
New year gift for our 2015 25 fc. Purchased a 2.1 gallon expansion tank/accumulator at home depot. Installed under sink in bathroom. Put a tee on accumulator, one leg goes to cold water supply line. Other leg goes to cold water at faucet. What a wonderful upgrade. Water at galley runs nearly 15 seconds before pump runs. We can flush the toilet 4 times without running the. Pump.
Yes the pump runs longer when it does run, but flow rate is very uniform.
Most importantly my wife loves the home- like water flow.
Stormalong is offline   Reply With Quote
Old 01-01-2016, 10:30 PM   #17
dznf0g's Avatar
Oswego , Illinois
I did this in my old sob, but it was a 1 gallon tank from grainger. Worked well, but that was an old single speed basic pump. I have never felt the need with the AS with the variable speed pump.
-Rich-
What size Accumulator? '07 Bambi 19' Phantom Fresh Water Systems 10 08-21-2007 08:56 AM
New Water Pump or Accumulator Al - K4GLU Water Heaters, Filters & Pumps 4 08-15-2007 09:45 AM
Why no accumulator? Roger S Fresh Water Systems 29 08-09-2007 06:30 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
