Old 08-27-2011, 06:08 PM   #1
Walker , Louisiana
'76 sovereign fresh tank?
What is the bolt on the steel plate under the camper by the fresh water tank in the middle in front of the axles and how do you drain the fresh water tank?
Treyladut is offline   Reply With Quote
Old 08-27-2011, 07:08 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That bolt holds the center of the plywood up.
The drain should be on the curb side, and should look like a red handled faucet.
Old 08-27-2011, 07:45 PM   #3
Walker , Louisiana
If I removed that bolt will that give me access to freshwater tank?because I have a leak from the fresh water tank.
Old 08-27-2011, 09:11 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
My fresh tank drain is the pump. Run it till it quits pumping water.
sovereign
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
