Old 05-29-2007, 12:00 PM   #1
1976 27' Overlander
Hackett , Arkansas
'76 Overlander Shower/Copper Tubing
I need to replace part of the copper tubing going to the shower faucet on my 1976 Airstream Overlander. Most of the copper tubing in the Airstream is 1/2 inch; however, a section I had to repair under the sick was 5/16. Before I remove the section behind the shower, I want to determine the size of the tubing so I can buy the correct fiitings. I have been told that all of the smaller tubing behind the shower is 3/8. Does anyone know whether or not the copper tubing going to the shower faucet is 5/16 or 3/8?
sugarloafin' is offline   Reply With Quote
Old 05-29-2007, 12:47 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings! Are you replacing the section with copper? I would convert it over to PEX. You are going to save a ton of time, money and weight. Lowes now carries it!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-29-2007, 02:24 PM   #3
1976 27' Overlander
Hackett , Arkansas
Yes, I have been making all repairs by replacing the copper line with PEX. The PEX line is great and easy to work. There are 1/2" and 3/8" quick connectors for PEX that just slip on the copper tube and the PEX line. This is convenient and easy. However, there is not a fitting for the 5/16" and I will have to use a copper compression fitting if the tube behind the shower is 5/16". I'm hoping that it's 3/8".
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
1960 Overlander 66TradeWind 1960 - 1964 Overlander 2 10-23-2002 09:27 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
Looking at a '64 Overlander N80 1960 - 1964 Overlander 1 06-02-2002 08:25 PM
