Old 01-31-2011, 10:40 PM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
'75 TW fresh tank removal 1 man
I tried getting my fresh tank out by myself today. I got all the belly skins off the front. (not for tank removal but for filth removal) I tried the bolts after hours of penetrating oil. They broke anyway!! I got all the sealer loosened and tried prying the plywood forward with a prybar. I got it forward about 4 inches. That's as far as I can get it so far. I've got to use my knoggin to figure this out. Unless there is someone out there that's done this one-man and can share?
Ed/Breadbug
ID:	121126   Click image for larger version
ID:	121128   Click image for larger version
Breadbug is offline   Reply With Quote
Old 02-01-2011, 05:51 PM   #2
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
So I think I might have an idea. If I screw something with a ring attached to it onto the plywood under the tank. Then using my heavy duty chain attached to that ring and the ball on my TV. Pull forward slowly and slide the plywood out onto a piano dolly. I know the trailer jack will be forward of the plywood as I pull so I will use a spotter. I'm replacing the tanks so if they just drop out it will be ok. What do ya think? Risky?
Ed/Breadbug
Old 02-01-2011, 06:01 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Do it! Do it!
Pics please..
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-01-2011, 06:18 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Most of the resistance is from the really, really thick plywood rubbing on the really, really rusty frame. Try lifting the plywood up a bit with a floor jack, and roll the floor jack forward. If it won't come out, you can still try your plan B.
Old 02-01-2011, 08:31 PM   #5
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
I went lookin for my dolly and I must have loaned it out. Darn if I can remember to who! When all else fails....use your brain. Or just use a chain and your TV. Ha ha
Ed/Breadbug
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 08:32 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 11:46 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 05:10 PM
