Old 01-18-2011, 03:51 PM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
'75 Tradewind replace tanks?
I found a crack in one of my freshwater tanks right at the gooseneck where the feed line connects. I assume I will have to replace the tank? Here's the question. Should I remove the floor from wall to wall? Can I just cut the center out? Will I loose too much structurally? I'm gonna por15 the frame that I have access to too. I'd post pics but I haven't figured out how with my iPhone. Thanks
Breadbug is offline   Reply With Quote
Old 01-18-2011, 06:05 PM   #2
1960 24' Tradewind
Riverside , California
The tank removes from the bottom, held in place by a piece of 1" plywood, cover by a piece of underbelly aluminum, all secured by a stick of steel angle across the front edge of the plywood. Easy to remove if the plywood is dry, not so if it's wet.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 01-18-2011, 08:51 PM   #3
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Thanks Greg. I haven't gotten my manual in the mail yet. I looked under the belly first. I didn't see anything obvious. I thought, "shoot!, I have to go from inside?" I hope it ends up as easy as it sounds it could be.
Old 01-21-2011, 11:53 AM   #4
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Finally got my manuals. Yippy! So now I have no excuse for mistakes, right?! LOL
Can you replace Keller Door lock on a '73 Tradewind with a Bargman L-400? montanablue Windows, Doors, Locks & Vents 3 10-06-2011 01:39 PM
Complacency In Today’s Economy Spells Vanishing Tanks and/or Shore Power Cords! overlander64 Our Community 34 08-18-2011 11:58 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
75' Tradewind replace tanks? Breadbug Fresh Water Systems 7 03-06-2011 10:11 AM
