Old 04-05-2011, 02:46 PM   #1
1974 25' Tradewind
Langley , Washington
'74 Trade Winds..broken water line
Help---The cold caught me and there's a break in the water line. How do I go about taking things apart to find it? Closet panels are all riveted how do I dismantle and reinstall? Thanks.
Ameliasdad is offline   Reply With Quote
Old 04-05-2011, 03:27 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Greetings, Ameliasdad, and welcome to AirForums! I'm sure you'll find lots of information about how to access your water systems here!
Lynn
WBCCI 21043
Old 04-06-2011, 07:13 PM   #3
1973 29' Ambassador
Columbia , Missouri
Well it depends on where the water is coming from to begin with, my 73 ambassador has lines in the kitchen and bathroom and between the tank and the water heater, but no lines in the closet. There is only one line that I cannot access and it runs from the tank to the bathroom and I can see it from the tank access panel on the belly of the trailer.
Jakewith72as is offline   Reply With Quote
Old 04-06-2011, 07:58 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Greetings and welcome to the Forum.
Where the line is, and if itís a hot or cold pipe makes a big difference in the repair.
One of the previous owners neglected the plumbing and both the hot and cold lines split in the closet on my TW double. Someone fixed these by blobbing as much solder over the split as they could smear on. It was easy to get to.
If itís under the sink cabinet, by the water heater, in the bathroom or the city water line it gets much more involved. As youíve discovered, the cabinets are a pain to get out or disassemble.
Let us know where the pipeís gone bad and maybe we can point you in the right direction.
Good luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 04-06-2011, 08:04 PM   #5
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
You can drill out the rivettes with a 1/8 drill bit. I am currently gutting the interior of a 74 Tradewind for renovation. If you take all of the drawers out of the little dresser you should be able to see the 2 water lines below if that is where the leak is. The drawers just slide out.on mine, the PO had repaired a couple of leaks in the closet and under the dresser with heater hose and circular clamps.
Baseman is offline   Reply With Quote
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Gas line to water heater '73 International cuyd Water Heaters, Filters & Pumps 13 04-04-2011 09:47 AM
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
