Old 10-18-2011, 10:01 PM   #1
1975 Argosy 24
Pensacola , Florida
'74 argosy water?
Just bought a 1974 argosy 24'. When I turn the 12v pump on the water pumps out the city water hook up (not form the sink). Is there some sort of a valve that is broken or open? If so where is it? or can I just screw in a garden hose shut off to stop the flow at the city input.
thanks in advance
Sky
bigsky71 is offline   Reply With Quote
Old 10-18-2011, 10:12 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Welcome fellow Argonaut! We love our Argosy24.
There should be a checkvalve to prevent that. It's either been removed or it's stuck. For a short-term fix for boondocking, you could just cap the city fill. Before you actually hook up city water, you want to have the checkvalves working because there's another one-way valve to stop the city pressure from flowing to the pump and fresh water tank.
David
Old 10-18-2011, 10:21 PM   #3
1975 Argosy 24
Pensacola , Florida
that was quick. Any clue where those valves may be or should have been?
as a side note it did not back fill the tank when it was hooked to city water, so I guess it must have at least one valve in place.
Sky
Old 10-18-2011, 10:49 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
According to Airstream there aren't any service manuals for Argosy trailers, but I have a '75 Airstream service manual. Looking at the water distribution system for 23 & 25 ft '75 Airstreams, it shows the water inlet, then the regulator assembly a little inboard of the inlet with a checkvalve listed as part of the regulator assembly. There is no indication that the drawing is to scale, but it looks like it's within 2' of the inlet.
David
Old 10-18-2011, 11:08 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In my '74 26' Argosy all of the valves etc are located in the closet of the rear bath. I remodeled the bath and installed PEX tubing throughout. I installed a ball valve in place of the check valve for city water, that way I know for sure that it is on or off.
Old 11-01-2011, 02:53 PM   #6
1975 Argosy 24
Pensacola , Florida
thanks
I will be working on it this week
Sky
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
