Old 04-27-2009, 06:56 PM   #1
1971 27' Overlander
Perkinston , Mississippi
'71 Overlander Leaky Pipe
I need copper water pipe fittings, cap or coupling. Can't seem to find what I need at the local hardware places. Any suggestions on where I can find or order the correct parts?
LCHolloway is offline   Reply With Quote
Old 04-27-2009, 08:20 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Is it the size you can't find - 5/8ths - or is the tubing 1/2 and nothing in 1/2 is large enought to fit it.
Old 04-27-2009, 09:28 PM   #3
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I found that in repairing the copper plumbing in the Overlander and Sovereign ('72, '73), I could not use standard couplings to sweat to original copper.
I don't know if it expanded over time or never was the same diameter, so I used a plumbing tool known as a swage to enlarge the existing copper to accommodate the new stuff.
Here's a picture of one (being used for another application).
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 04-29-2009, 06:07 PM   #4
1971 27' Overlander
'71 Overlander reply
3/8 is too small and 1/2 is too big. I was thinking that I had to order a specific airstream part, but that's not the case Thanks for any help
Old 04-29-2009, 06:10 PM   #5
1971 27' Overlander
Thanks for the picture
Thanks at this point we're willing to try anything!
Old 04-29-2009, 06:14 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
What has happened is at sometime your 3/8 line froze,and expanded.You can probably
swag it and slide a 3/8 inside and solder it.Dave
easyride is offline   Reply With Quote
Old 04-29-2009, 06:49 PM   #7
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
I just went through something similar w/ my '74 Overlander. One of the copper pipes was thin-walled copper...comes in coils rather than straight lengths. It had froze & expanded. It wasn't big enough to accommodate normal 1/2" fittings (which are really looking to be fitted on to a pipe of 5/8" outer diameter). I visited my local plumbing supply store (specific to plumbing...not Lowe's or anything like that). They had enough copper such that their store was worth more than Fort Knox. Anyway, he ID'd the problem and just went through the stocks until he found the fittings I needed plus found a length of 1/2" copper that fit my expanded pipe just right. So, I cut the long length into short lengths and sweated them on to the expanded pipe. Now, I had true 1/2" copper pipe (actually 5/8" OD) that I could get my sharkbite connecters to grab onto so that I could install PEX to replace the copper section that had burst.
Pain in the butt. The problem was one of a few that prevented me from attending CBR with the WDCU this year. But, I learned a lot through the process.
WineStream is offline   Reply With Quote
coupling, fittings, pipes, plumbing, leaks
Leaky Shower chipw Sinks, Showers & Toilets 7 08-25-2017 08:39 AM
Leaky / Overflowing AC... crazy.philip Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-05-2008 07:45 PM
help with leaky roof!! fancy pants Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 05-21-2007 06:26 AM
Leaky Excella Steve Heywood 1997 -2001 Excella 13 02-19-2006 02:35 PM
leaky used 04 28 ccd annw Our Community 16 01-20-2006 09:40 PM
