Old 07-22-2010, 03:48 PM   #1
1976 31' Sovereign
Unhappy 7/16 OD pipe?
I have removed 3 of the pipes from under the sink area. When I did so, I assumed that they were all 3/8ths, 1/4 and 1/2 inch. One of the pipes though, that leads to the shut off valve just below the sink seems to be 5/16ths ID or 7/16ths OD. Finding a fitting to go from copper to PEX has been a nightmare. I've replaced everything else successfully with PEX and sharkbite fittings. Any suggestions? If I had known it was such a freakish size I wouldn't have cut it out
wallybgirl is offline   Reply With Quote
Old 07-22-2010, 04:05 PM   #2
It only became a freakish size, when it froze.
Those sizes do not exist, until copper tubing freezes.
Best you replace any and all copper tuubing that has a goofy size. You will also find that the sweat solder fittings, which also stretched, are now weak, and are great for failures, when you least expect it.
Replace all the tubing that is off size,as it will save you much grief, down the road.
Old 07-23-2010, 09:52 AM   #3
1976 31' Sovereign
i actually think someone replaced that length of pipe with refrigeration tubing...but I think I will just take it out to make my life easier...
Old 07-23-2010, 10:12 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have a 64 here with a fair amount of 7/16 copper tubing. This one definitely froze. As Andy said, there is no 7/16th size.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-23-2010, 12:43 PM   #5
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
Been there after some freezing!
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
pex, plumbing
Pipe Size? centennialman Fresh Water Systems 31 07-05-2008 01:30 PM
Waste pipe cap flitzwhopper LP Gas, Piping, Tanks & Regulators 2 11-04-2006 06:01 PM
Why black ABS pipe? Chuck Waste Systems, Tanks & Totes 2 03-25-2005 11:09 AM
Copper pipe help Crazyland Fresh Water Systems 26 03-03-2005 06:04 PM
