Old 07-15-2014, 07:31 AM   #1
Harperbear's Avatar
Arden , North Carolina
69 water tank and pump
I'm just getting started on my rebuild and am trying to move from the front to the rear and have a few questions.
Is the plastic water tank worth saving if it doesn't leak or does it need to be upgraded to a newer plastic. Same question with the pump. Not sure if it works so if i need to save it what is the best way to test it? Also under my sink i have a small chrome canister with copper lines that have been cut off. It is next to my heater. Is it a filter? Last one- how do i get the external water cap off? When i put a rag and a crescent on it it doesn't budge.
Harperbear is offline   Reply With Quote
Old 07-15-2014, 08:00 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Welcome.....Sounds like a project. Go at it slow and sure. The caps are notorious for that problem. I resort to PB Blaster and separately CLR cleaned and lime dissolver. The old metal tanks are junk,,,and you never know what has grown inside them over the years. A cheap fix is a new ABS type....I like the Valtera types better than the white poly ones. The canister sounds like a water filter....WE LOVE PICTURES!
Old 07-15-2014, 09:09 AM   #3
1974 Argosy 20
Kooskia , Idaho
You say the original water tank is plastic and does not leak. I would continue to use it then. The old PAR pumps were first class back in the day, but in my opinion the new pumps are superior in water pressure and delivery. I would plan on a replacement for it. The chrome canister is probably a water filter for the cold water line or a separate tap. The old cartridges are expensive, even if you can find them. I would just eliminate it if it were my rig.
Old 07-15-2014, 09:13 AM   #4
Harperbear's Avatar
Name:	ImageUploadedByAirstream Forums1405437176.326459.jpg
ID:	216394Click image for larger version
Name:	ImageUploadedByAirstream Forums1405437186.500805.jpg
ID:	216395Click image for larger version
Name:	ImageUploadedByAirstream Forums1405437200.764376.jpg
ID:	216396Click image for larger version
Name:	ImageUploadedByAirstream Forums1405437211.199479.jpg
Old 07-15-2014, 09:19 AM   #5
Harperbear's Avatar
Name:	ImageUploadedByAirstream Forums1405437530.885305.jpg
Old 07-15-2014, 09:20 AM   #6
Harperbear's Avatar
So no problems with drinking out of late 60s plastic?
Old 07-16-2014, 01:48 PM   #7
1974 Argosy 20
Kooskia , Idaho
None that I know of, if it was originally a fresh water tank.
Can't get water to pump from fresh water tank xbr443 Fresh Water Systems 6 01-20-2015 06:34 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
