Old 04-07-2010, 11:50 PM   #1
1969 31' Sovereign
Mount Vernon , Washington
'69 Sovereign water tank question
Well, folks... I was wondering... Aside from plumbing issues, is there any reason I couldn't turn my 30 gallon front-mounted fresh water tank on it's side and make room for a sofa in the nose? I know the sensor wouldn't work in this orientation. I also know I'd have to put in a new outlet nipple. The filler neck can also be fixed. What I'm hoping someone out there can tell me is: Will sitting on an edge (instead of lying flat on the deck) be a problem? I tried it, dry, today. It fits nicely under the front widow shelf. It frees up all that floor space for a standard sleep sofa and doesn't require me finding a sofa that will clear the ~7" it takes up from the floor.
Ellie & Carl is offline   Reply With Quote
Old 04-13-2010, 08:00 AM   #2
The tank should be supported on it's flatest side, so that it does not rupture.
You can add some small blocks to elevate the sofa.
Or, you can install a tank like those from the 64 to 67 models that's square, fits under the window and behind the lounge.
fresh water tank in '76 Sovereign ryan3326 Fresh Water Systems 7 01-17-2018 07:50 PM
replacement hot water tank for '76 Sovereign? ryan3326 Water Heaters, Filters & Pumps 7 02-22-2010 12:25 PM
1968 Sovereign water tank toaster68 Fresh Water Systems 0 02-09-2010 08:05 PM
missing fresh water tank on '76 Sovereign ryan3326 Fresh Water Systems 1 09-15-2009 06:51 PM
Anybody need a free fresh water tank for '69 Sovereign? bilby05 Fresh Water Systems 4 09-19-2008 03:03 PM
