Old 11-16-2008, 02:55 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
'67 Safari fresh water tank...
...what kind of plastic is it ? Any one have any luck fixing small cracks in theirs?
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 11-16-2008, 03:48 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I forget the type of plastic, but several vendors on ebay (search rv water tank) sell tanks for under 75 bucks that should fit. Not worth the water damage, if its cracking the plastic is brittle anyway.
this is the tank (and vendor) we bought for our 69
eBay Motors: Fresh Water RV Trailer Holding Tank 20 Gallon NEW (item 170278297277 end time Nov-17-08 21:15:38 PST)
goransons is offline   Reply With Quote
Old 11-16-2008, 05:01 PM   #3
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Thanks for the information...thats ALOT more affordable than I had anticipated!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 11-16-2008, 05:45 PM   #4
goransons's Avatar
1963 22' Safari
no problem, our tank was missing, but the idea of drinking out of a tank that may have had stuff sitting in it for up to 50 years (since they are never really totally empty and dry) is not real great. Those tanks have 3 options for output, so you can put it just about any direction.
Old 11-16-2008, 07:53 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Those are good tanks, but make sure it will fit where you can get the inlet to work.
I did fix some cracks in mine with a repair kit for plastic rads. Get it in an auto store.
The repair has held up for years. You can clean the tank out with bleach and rinse clean.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-19-2009, 12:51 AM   #6
toddster's Avatar
1967 20' Globetrotter
Campbell , California
Shacksman,
Thanks soooo much for this advise. I am leaving for Yosemite in the morning and discovered today that my fresh water tank was cracked. Your automotive parts store radiator tank repair kit did the trick. Don't think I'll be consuming that water anytime soon, but it is good for everything else.
toddster is offline   Reply With Quote
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Fresh water tank nilesrob Fresh Water Systems 4 09-16-2006 09:17 PM
fresh water tank 66 Safari Johndigbydog Fresh Water Systems 3 01-09-2006 10:28 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
