Hello all,
Kinda confused on water system. Obvious where water inlet goes into pump and floor drain but what is purpose of other valve/bypass line? Obviously I close drain valve when filling tank and while water system is in use. What do I do with other valve? Close as well or is there some reason to leave this open I'm not familiar with? Thanks all!
Airstream - Other
Bosque Farms
, New Mexico
It was designed so that you could fill the fresh water tank either from the outside inlet or via the water-connected line when you're hooked up to water at a campground. To do so, you connect to fresh water, turn it on, then turn the one valve in your picture to by-pass the pump and fill your tank.
