Old 05-17-2015, 10:03 AM   #1
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
'64 Globetrotter fresh water install
Hello everyone. I would like to share my fresh water setup I installed in a 64 Globetrotter. It was installed under the couch that was designed over the left wheel well. I installed a 20 Gallon tank, with a SHURflo 2.9 GPM pump. The intake is equipped with a external water pressure regular and then enters into a one inch diameter hose that goes into a sediment filter. I ran 1/2" clear tubing through the interior going to the outdoor shower inline water heater, outdoor faucet, and sink faucet. All lines were clamped and shut off valves were installed below the sink and exterior shower head. I vented the tank out towards the inner wheel well and sealed it up from the elements. I then insulated the entire tank, pump, and lines, being that we use this thing quite often in the winter time. As always input welcomed!
ID:	238604   Click image for larger version
ID:	238606   Click image for larger version
ArtisanAir is offline   Reply With Quote
Old 05-17-2015, 01:52 PM   #2
GlamperGirl
Thank you! I have gutted my 65 globetrotter. Really helpful posts in your work!
thumbelinadj is offline   Reply With Quote
Old 05-17-2015, 03:21 PM   #3
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Your welcome. We just recently finished our Globetrotter so if you need to know anything else, i'll be glad to help!
Old 05-18-2015, 08:37 PM   #4
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
By the Way...
Thanks are always welcomed. You know just starting out on the forum...
Old 05-19-2015, 09:07 PM   #5
chapparel's Avatar
1965 22' Safari
Three Rivers , California
I hope you don't get green algae in the clear 1" and clear 1/2" hoses.
"Life isn't about how to survive the storm,
but how to dance in the rain."
AIR #17571
chapparel is offline   Reply With Quote
Old 05-20-2015, 03:56 PM   #6
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Good point
I did notice that at one point it started trace amounts of algae form in the inlet hose and I went to a aquarium section at your local convenience store and bought an algae treatment for fish tanks. It has seem to clear it up and keep it from coming back. Another side note, we don't drink this water.
Old 08-01-2015, 09:07 PM   #7
tmeagle1's Avatar
Croswell , Michigan
Did you happen to do anything with the toilet?
Tim Eagle : Fiction
tmeagle1 is offline   Reply With Quote
Old 08-01-2015, 09:07 PM   #8
tmeagle1's Avatar
Croswell , Michigan
The reason I ask is I have a 1964 and I would like to change my toilet out with the new model.
Tim Eagle : Fiction
fresh water drain valve location '72 globetrotter? ssfletch Fresh Water Systems 6 09-28-2014 07:02 PM
'66 Globetrotter fresh water leak up front? GatlinDave 1965 - 1969 Globetrotter 1 07-06-2014 07:24 PM
fresh water tank for '66 globetrotter nbka1bm Fresh Water Systems 0 12-03-2007 12:59 PM
