Old 10-23-2006, 09:15 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
60s Water Inlet
I'm currently removing anything mounted on the trailer and resealing it and putting it back on before the rains come.
I've have taken apart the water inlet and find it very interesting. Obviously the flange is mounted with the three screws, but the pipe leading into the trailer just flops around in the flange.
I don't see how it's supposed to be secured. On the inside there was one lonely strap holding the pipe to the wall, but nothing else.
This thing twists around through normal use, so there must be a strong mounting system for it.
How is it supposed to be?
I don't intend to use it but I'd rather leave it instead of another patch job. But not at the expense of a easy leak point.
-Tim
theVAP - Airstream Podcast
Old 10-23-2006, 09:45 PM   #2
1960 24' Tradewind
santa barbara , California
hello Safari Tim, the water inlet pipe normally is threaded into the aluminum
or galvanized (whichever it is) tank ,the tank mounted on the curved brackets on the floor secured there with bands .so the pipe is rigid with the tank ,then the 3 screws of course .I would just cut the pipe going into the trailer short ,say enough to go inside the trailer then cut ,thats it ,but it needs a strap to hold it in place as you already know .so then to have the dummy water fill you just figure a way to secure the pipe so it appears normal
and cant move .
Scott
scottanlily is offline   Reply With Quote
Old 10-23-2006, 09:47 PM   #3
1960 24' Tradewind
Oh Tim , the water outlet points towards the ground in the stock or normal
position ,just like a regular faucet spigot.
Scott
Old 10-23-2006, 09:58 PM   #4
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Ah, that makes sense now. Of course my tank was missing so I had no idea.
I already sealed it back up with the faucet facing up
Oh, well I always wanted to be different!
So originaly to fill the void as the pipe entered the trailer, was it just filled with vulkem? That's what I did. It seems to me like the whole assembly can move easily though even being strapped to the wall on the inside.
I'll have to revisit it and decide a better mounting method when tankless....
-Tim
Old 10-23-2006, 10:11 PM   #5
1960 24' Tradewind
yeah ,just fill it with vulkem . The pipe can't move period when it threads in the tank in any way ,its all very rigid ,doesn't have an inside strap on my trdwnd ,never did ,cannot move it .The upside down parts ok .no one will try to put a hose on it that way .
Scott
Old 10-24-2006, 12:19 PM   #6
Mom scared by aluminum
dmaiden's Avatar
Phoenix , Arizona
Hey Tim, you're lucky. Mine is still in my tank and I can't get it out. Because of the angle, I can't take my tank out. I think I may have to go nuclear (anyone have Lil' Kim's number?). A big pipe wrench is having little effect.
Dave and Joanne
1963 Flying Cloud
2005 Silverado 4x4 3/4 Ton
dmaiden is offline   Reply With Quote
Old 10-24-2006, 02:23 PM   #7
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thats right Dave. I hadn't thought about it that way. I wouldn't have used it anyway after hearing how they look inside.
So I'm good to go.
-Tim
Old 10-25-2006, 12:49 AM   #8
1960 24' Tradewind
It needs to be stainless steel tank like i have in my 60 trdwnd ,the old tank
really was a piece of trash ,terrible inside ,and the first thing I took out
after the gold plastic aqua magic toilet .
Scott
Water Inlet Tube watertalks Fresh Water Systems 6 02-14-2012 09:30 AM
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
Locating new city water inlet Globie64 Fresh Water Systems 12 03-10-2011 08:55 PM
Placement of new water inlet??? robwok Plumbing - Systems & Fixtures 14 03-02-2011 09:01 PM
