Old 05-05-2009, 01:42 PM   #1
1960 24' Tradewind
Fairfield , Ohio
'60 Tradewind plumbing
I am replacing the floor in the front of my 1960 tradewind. I'm wondering if I should replace the freshwater tank and plumbing while I have the floor out. I haven't tested the tank yet, but it doesn't look to good. I'm guessing that the pump next to the tank pumps the water through the system, but I am confused about the the air fitting on the the fill tube. Any help would be appreciate. Thanks'
Dave
WcfdPiper is offline   Reply With Quote
Old 05-05-2009, 01:45 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I believe (w/o seeing pictures) you have a pressurized system, at least that's what they came with. You could use the pump to pressurize the tank or you could get out your bicycle pump and pressurize it. And we'd love to see pictures.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 05-05-2009, 01:55 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Depends on the originality to function balance you are trying to strike. If it were me I would say the heck with originality and rip that puppy out and replace it with a new tank and 12 volt pump. But you may feel otherwise and want it just like it came out of the factory. Btw, if you replace it and the plumbing, consider using PEX for the pipes- easy to work with and more durable/forgiving if it freezes.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-05-2009, 03:01 PM   #4
1960 24' Tradewind
Fairfield , Ohio
Is PVC like PEX? Never heard of PEX. Thanks for the help.
Old 05-05-2009, 03:04 PM   #5
1960 24' Tradewind
Fairfield , Ohio
So the system is not reliant on air pressure. That makes sense. I'm going to go out and see if a bicycle pump fits it. Wow, lots to learn about!
Old 05-05-2009, 03:05 PM   #6
1960 24' Tradewind
Fairfield , Ohio
Does it make sense to do the plumbing while the floor is out or should I worry about one thing at a time?
Old 05-05-2009, 03:05 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by WcfdPiper View Post
Is PVC like PEX. Never heard of PEX. Thanks for the help.
PEX is plastic, how much it is like PVC I cant tell you. The connections are hand fit and do not require glue, the kind I used in my 68 can be taken on and off quite easily. Just do a search on PEX and you will find tons of information.
Rodney
and the
My Blog
Old 05-05-2009, 03:06 PM   #8
1960 24' Tradewind
Fairfield , Ohio
Mark can you send any pictures of your Tradewind? I'd like to compare it to the mess I have!
Old 05-05-2009, 09:37 PM   #9
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Thanks for asking . . . this is mine just before I "tore into it". It was an Ohio Built w/Twins. It looked a lot better in pictures. The closer I looked the more "worms" I found until eventually they all got out of the can - I slipped down the slippery slope and now it's gutted, lots of new plywood sub-floor, all interior walls out, new insulation, lots of work still ahead. Post some pictures when you get a chance. And good luck.
MarkR
1960Tradewind6
Old 05-07-2009, 04:09 AM   #10
Arrowstream's Avatar
Columbia , South Carolina
The air fitting on the fresh water tank is most likely a vent to let air in/out of the tank as it is being filled/emptied.
Arrowstream is offline   Reply With Quote
Old 05-07-2009, 05:47 AM   #11
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Instead of a pump, you may have the original air compressor that pressurized the tank. Check out a blog by Airforums member Sugarfoot. She recently dealt with replacing the tank on her 1960 Tradewind trailer. Enjoy Traveling With Elvis
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-13-2009, 06:50 AM   #12
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Hi WcfdPiper, yes I've replaced my tank but not the plumbing yet. If you've got your floor out and can get to everything, I'd bite the bullet and replace all before something goes wrong on the road. I've had broken plumbing on the road and it's not fun. I stayed with the pressurized system because I'd already replaced the compressor. I had a sheet metal fabricator make the tank to original specs, and a metal machinist thread the fill neck and install the compressor fittings and Schrader valve. All works like a charm now.
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 05-13-2009, 09:13 AM   #13
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Early TradeWind Plumbing
Welcome wcfcPiper. Yea!! Another early TradeWind owner. On mine, I had the original cylindrical aluminum pressurized water tank but the pump or compressor was already missing. I elected to take out the tank and replace it with a rectangular one made to my specifications from All-Rite.com. I gained quite a few more gallons of capacity and then I put in a 12 volt AquaJet pump. All of the original copper fresh water lines were replaced with PEX and the cast iron waste water lines were replaced with ABS. Installing PEX is fairly easy as it is flexible, easily cut and the connectors don't require special tools. In one of the photos, you can just make out the white poly tank nestled into the seating area under the window. It holds about 23 gallons as opposed to the original tank's 15 or so.
Now I'd like to learn more about this TradeWind of yours so I can add it to my early TradeWind registry. Post some pix when you can.
FF
ID:	80130   Click image for larger version
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 05-13-2009, 03:23 PM   #14
1960 24' Tradewind
Fairfield , Ohio
Thanks Brad. Your before pics look a lot like what I'm dealing with now. Was your custom tank expensive? Someone else suggested the PEX as well. I am in the process of replacing the front floor and am wondering if I should do the plumbing then replace the floor or do the floor then the plumbing. My thought is floor then plumbing. My refrig is completely destroyed and I am considering going just electric. The 2 ways are VERY expensive. I'll post some pics.
Dave
Plumbing rollingbubel Fresh Water Systems 2 02-23-2009 11:22 AM
Why shouldn't I do this with the plumbing.??? purman Plumbing - Systems & Fixtures 9 09-12-2008 01:42 PM
'59 Tradewind plumbing question bgarver 1959-69 Tradewind 2 08-26-2007 10:22 PM
Plumbing my A/S blucloud Fresh Water Systems 4 06-11-2004 06:16 PM
Need new plumbing? wardster All Argosy Trailers 5 08-17-2003 10:08 AM
