Old 03-18-2007, 08:36 PM   #1
1976 31' Sovereign
Charlotte , North Carolina
1976 Sovereign Water Fill Door
I have purchased a 1976 which I had to drill out the lock to open the curbside water fill door because the previous owner lost the key. Inside, I observed a fill hole but no cap or plug. Unfortunately the door flopped open before I found the correct lock and it flopped open during transit and upon entering the campground, I barely hooked it on a roll out trash can. It broke part of the bottom hinge off and tore out the plastic box frame from the inside.
someone please respond as to what should be normal and where can I find a replacement cast door,lock and whatever goes in the filler hole if anything at all.
Any help would be greatly appreciated.
Badco8 is offline   Reply With Quote
Old 03-18-2007, 11:02 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1977 25' Tradewind
Eastern , Washington
Could you post a picture so that we can see exactly what type it has installed. If it is a flip down type not a door to the fill cap. The flip down type is no longer available to my understanding. There are fixes for most types.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 03-19-2007, 07:14 AM   #3
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
Check out this thread.
If you have all of the pieces, you may be able to reassemble it. I rebuilt mine on a '73 Sovereign using Evercoat fiber reinforced epoxy (bondo)for similar reasons and it is working fine. Getting to it from the inside is a lot easier if the coach is gutted (mine was at the time).
You'll have to disconnect the filler hose and remove the housing from the inside of the exterior wall (it is firmly attached with vulkem and olympic rivets on the outside) and care must be exercised to avoid further breaking. (It is very brittle.)
Once it is repaired, re-installation should be done with some sort of backing washers on the rivets to avoid cracking the housing (again, it is brittle).
Another option (assuming you can make the door stay on) is to insert a long flexible hose from the outside and fill the tank using a funnel.
ID:	34148   Click image for larger version
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Where can I find a Minuet water filler hatch? Janets Husband Fresh Water Systems 9 05-12-2004 08:45 AM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
