Old 05-25-2008, 05:44 PM   #1
deep river , Connecticut
1971 overlander rear bath city water hook up
I found the city water hoop up, ran my hose to it and cant get water to flow do i need to run the pump or no? Also is there a shut off that I might be missing?
durbin is offline   Reply With Quote
Old 05-25-2008, 06:28 PM   #2
. , At Large
I may be the pressure regulator is stuck shut. It is not uncommon, our Sovereign had the problem before we acquired it. It should be located in the rear compartment, to the left as you are standing behind the trailer.
Old 05-25-2008, 07:29 PM   #3
cameront120's Avatar
1972 25' Tradewind
North Vancouver , British Columbia
Also make sure all the drain and supply valves are opened or closed as appropriate.
North Vancouver, BC
cameront120 is offline   Reply With Quote
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
2005 Interstate rear bath-water on floor after a rain herrgirdner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-17-2007 09:17 PM
Early Model City Water Hook-up ga501 Fresh Water Systems 1 03-27-2006 07:59 PM
Water damage to the Rear Bath, '75 Tradewind balrgn Repairing/Replacing Floor &/or Frame 2 11-25-2004 03:37 PM
'85-34ft Sovereign City Water Hook up E&T Stutts 1984 - 1989 Sovereign 1 10-31-2002 06:31 PM
