Old 03-20-2015, 03:04 PM   #1
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
'15 Classic with Moen Sensor Faucet
Thought I'd go hi-tech and install a Moen Sensor faucet in my kitchen. It comes in the "easy care" stainless steel, and was an easy install. The sensor mechanism uses either a battery pack (6 AA batteries), or you can opt for a 120V converter. Obviously, I stuck with the standard battery pack. The most difficult part of the install was removing the Kohler that came in the trailer. Will see if this faucet does what it promises (among other things), as a water saving device. Several nice features. Easy to deactivate (hold your hand over the top sensor for awhile), or reactivate. Equally neat, if you start running the water and don't shut it off in two minutes, it shuts off by itself. If you choose, you can use the regular handle as well. In appearance, it looks almost identical to the Kohler -- has same pull out/spray function, water shut-off on the spray unit, etc. Cost is around $350.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-20-2015, 03:59 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Another addition to my BAB & switz list of must haves. Jim
Jim Flower is offline   Reply With Quote
Replacing Moen Cartridge on Shower Faucet Derin_Don Plumbing - Systems & Fixtures 17 10-20-2016 02:23 PM
Moen Pure Touch Classic Kitchen Faucet Airperson Sinks, Showers & Toilets 15 05-07-2010 07:04 AM
'77 Moen faucet parts LI Pets Fresh Water Systems 6 12-18-2006 09:26 AM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 06:21 PM
