Old 07-24-2012, 05:56 AM   #1
1974 27' Overlander
Perryville , Missouri
1/2" pex to and from the water pump
I'm re-plumbing my 1974 27' overlander with 1/2" pex and now I'm up to the water pump (which I'm replacing with a new shur-flo pump). My question is can I use 1/2" pex everywhere, including into and out of the 3 gpm pump, or do I need something larger. My old pump was plumbed with something larger that looked like water hoses.
Thanks for the help.
ericc is offline   Reply With Quote
Old 07-24-2012, 06:39 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
1/2" is fine. Just get fittings that fit your pump. The larger hoses might be a replacement or repair by a PO.
Chris
Old 07-24-2012, 06:43 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would use a flexible connection to prevent more noise from the pump being transferred to the PEX and have it rattle throughout the trailer. Put a 1/2" female threaded fitting on the end of the PEX then screw in a hose barb fitting of the appropriate size for the hose.
TG Twinkie is online now   Reply With Quote
Old 07-24-2012, 07:17 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I put in a new water pump and plumbed it with Pex. I put in a U loop to give it some flexibility in positioning. Works fine and makes less noise than the old pump with the hoses. I did not go all the way into the tank. I put a barb to Pex at a easy to access place at that end.
Old 07-24-2012, 09:17 AM   #5
1974 27' Overlander
Bill, do you have any pictures of this set up?
Old 07-24-2012, 10:40 AM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
1/2 inch is fine. thats what I used. I have two fresh tanks going into one pump. you can see a picture of my set up here: http://www.airforums.com/forums/f174...a-90934-8.html Post #104
I put in a bypass to fill the tank under the trailer. you can't see it in the picture but I put the foam wrap pipe insulation around all my pipes to reduce noise. You can hardly hear it any more. It use to bang and vibrate before..
I just have some screw on fitting for the pump and they come off easy.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
