Old 03-29-2008, 01:49 PM   #1
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
ZipDee pull strap repair
All my previous trailer awnings had a removable pull strap that could be slid to the end and removed. When I saw that my current trailer's pull strap was rotted on the end from the sun, I thought it would be a simple replacement.
Instead, I had to come up with a repair because my strap is sewn into the awning fabric.
First is the photo of the rotten strap, followed by the repaired strap made from 1" webbing and riveted on. The "large side" of the rivets rub on the aluminum cover, not on the awning which would otherwise wear.
ID:	57220   Click image for larger version
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-29-2008, 01:51 PM   #2
We'e got the same problem withour awning pull strap. It looks like you used rivets to hold the strap in place. Where there any interference issuses with the rivet heads?
Thanks!
Old 03-29-2008, 01:53 PM   #3
Fyrzowt's Avatar
Images: 8
Originally Posted by bkahler
We'e got the same problem withour awning pull strap. How did you fasten the replacement piece in place?
Thanks!
See my edited post. If someone were handy with a machine, it could be sewn and may look more professional. The machine would have to be moved to the awning as the strap won't come off.
AIR #15800
2000 Safari SS 25'
Old 03-29-2008, 01:57 PM   #4
Thanks for the clarification. Using a sewing machine would definitely be a logistics nightmare!
Old 03-29-2008, 02:17 PM   #5
_
fryz...
did you contact z/d about a free replacement strap? was this not covered?
for older awnings replacing the ENTIRE STRAP might be a better approach.
simply remove the strap at the roller (cut the stitching or drill out the rivet...
then re-rivet to the ROLLER
or use brass grommets on the cloth (less desireable) which would also provide drainage.
cheers
2air'
Old 03-29-2008, 02:20 PM   #6
Fyrzowt's Avatar
Images: 8
Originally Posted by 2airishuman
fryz...
cheers
2air'
Nope. Eight year old trailer and third owner, it never crossed my mind. I just fixed it.
If it turns out to be the case, nothing lost. I can still replace the whole strap.
Dave
AIR #15800
2000 Safari SS 25'
ZipDee Chairs on EBAY gmshadow Our Community 6 09-24-2006 01:39 PM
ZipDee DIY azflycaster Awnings 10 04-29-2006 08:21 AM
R.I.P. ZipDee nettepdx Awnings 13 09-06-2005 12:08 PM
Pull-out bin repair TomW Cabinets, Counter Tops & Furnishings 12 09-07-2004 08:46 AM
Repair/Replace ZipDee Chair Fabric???? Tammy Upholstery, Blinds, Walls & Interior Finishes 3 08-01-2004 03:27 PM
