Old 09-19-2017, 08:53 AM   #21
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Mine was manufactured in August, we took delivery in late September. Mine appears to be different from others so, I like different.
Bud
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 09-19-2017, 08:55 AM   #22
paiceman's Avatar
Originally Posted by james.mileur View Post
I ran around this problem after delivery as I read the manual about the Store button, but when in Store, all DC went dead. Thought it was broke, found out Delivery Dealer doesn't have drawings, contacted CS @ AS and found out that portion of the manual was incorrect (to be revised). On page 8-15, push the Store button, the PMM disconnects power to the G6 (DC push button fuse panel), all DC goes dead. The switch is under the rear dinette seat on mine. AS confirmed that was the way it was (supposed to be). You should be able to hear it switch on and off with the Store switch. Doesn't disconnect the DC fuse block for jacks, 7-pin cable, batteries, CO monitor, and brakes. The Inverter should still work, based on the drawing, never tried it in Store.
Under rear seat of Dinette? I've got nothing but a mess of wires, which I straightened out. No switch.
I was actually told by AS, as I posted that the inability to shut the DC off when connected to shore power by putting the battery disconnect in store was what is correct. Seems: Another rolling change?
Bud
SAFE TRAVELS
Bud
Old 09-19-2017, 09:25 AM   #23
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Hi
So... when did each of these trailers leave the factory? I believe mine came out in September.
Mine built/delivered in Oct 16. So, Bud, your DC panel stays on in Store mode means you're missing a switch module that is shown in the drawing. Take another look in that rats nest for a 4" x 6" panel with two big red wires and cat 5 cable, maybe. Do you have DC fuses on front of the converter or the G6 panel with push button fuses under right wardrobe?
If it doesn't kill the DC distribution (less vital loads), what good is the Store switch?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-19-2017, 12:26 PM   #24
paiceman's Avatar
I will check next time I am over to the storage facility under the dinette seat, but I am pretty sure I'd have noticed a 4"x6" panel when working in their and vacuuming all the sawdust. Mine are push button fuses under the right hand wardrobe door and over the converter under the left wardrobe have only circuit breakers.
The Store Switch I was told is to disconnect the batteries only when the trailer is not connected to shore power, which will save the batteries from all but the monitors we cannot turn off, the inverter if left on or anything is plugged into an inverter only outlet.
This is great.
Bud
SAFE TRAVELS
Bud
Old 09-19-2017, 12:47 PM   #25
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I most certainly would *not* take any of this as "right vs wrong" in terms of how the trailers are set up. It's just another wrinkle in the great AS saga of partially documented stuff.
As far as I can tell, the inverters are all wired directly to the battery. It's one of those "phantom" loads you can't do anything about. It's high enough current / sensitive to cable loss that it's better to do a straight run.
We have Hurricane Jose pumping wind and rain into the campsite here. The dogs just knocked over the water bowl so I was crawling around on the floor / pulling panels to mop that up. I confirmed a couple of wiring questions doing that. (My sub woofer *is* dead nuts in the middle of the sofa ...). I may dig in under the dinette next. I haven't been poking at the Alde stuff in weeks ....
I still haven't quite worked out how to pull the "Firefly" panel that's under the wardrobe. It seems like it should be easy, but I haven't either applied enough force or found the magic catch ....
uncle_bob is online now   Reply With Quote
Old 09-19-2017, 01:16 PM   #26
Obviously-NOT
Kalispell , Montana
Firefly under the Wardrobe? You mean the DC panel, G6? The 30 year service guy at delivery told me, "that's one of those panels you don't want to open too often, due to all winky little connectors that get flexed when you remove it and reinstall it. "
The two finger holes on the sides are only moderately useful. The snap hooks are at 12 and 6 positions, rocking back and forth helps.
Old 09-19-2017, 01:53 PM   #27
Half a Rivet Short
Hi
Yup that's the one. I've tried the rock back and forth a bit. I'm more curious than anything else. I certainly don't want to disable the world by breaking off a connector.
Old 09-19-2017, 01:57 PM   #28
Obviously-NOT
Kalispell , Montana
I'm up to about 4 out and in cycles, with no known deficiencies.
Old 09-19-2017, 03:05 PM   #29
Half a Rivet Short
Hi
So with the "assistance" of the dogs, I've done some exploring under the rear dinette. The magic panel is indeed lying there in the middle of a bundle of wires (...yikes ...). The red wires into it are set up to do a "everything dies" disconnect. It would be very easy to move the one wire over to the other post, either by plan or by accident. I now have yet another 3D printing task for the AS. The back of that panel needs some sort of protection ....
Old 09-19-2017, 03:17 PM   #30
Obviously-NOT
Kalispell , Montana
Hi
What, exposed circuit board pins not to your liking? Make two, I'll pay for shipping and send a coupon for some Red Bridge.
Old 09-19-2017, 03:31 PM   #31
paiceman's Avatar
My dogs and I went to Home Depot today. They love it there, almost as much as Hospitals and Nursing Homes. No AS work today or this week, tomorrow Jury Duty calls.
Bud
SAFE TRAVELS
Bud
Old 09-19-2017, 03:33 PM   #32
ksteve06's Avatar
mcdonough , Georgia
When I hit store while plugged into shore power everything turns off. Ours was built April 2017.
ksteve06 is offline   Reply With Quote
Old 09-19-2017, 03:53 PM   #33
Half a Rivet Short
Hi
Once I get it figured out, I'll make a bunch of them. I'm sure you will not be the only one interested. Having that big un-fused 12V post bang into a grounded piece of metal does not look wise at all. I had a friend take out a Huey with that sort of "aw shucks" move. Big chunk of the frame gone ....
Old 09-19-2017, 09:07 PM   #34
mojoe7009's Avatar
Green Cove Springs , Florida
Mine was VERY early! Probably a show unit that ultimately was shipped to the dealer. Based on the level of issues and missing items I would bet on it. Never got reworked before it was sent. I didn't even have a mixing valve when it was delivered. That's just one example.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 09-20-2017, 12:42 AM   #35
Reads a lot
Titusville , Florida
Jumping in here late,when I hit "store" everything dies. I am still trying to figure out if that is a good thing or a bad thing. Mine was built late Sept, I think. I am nose deep in major projects right now but will go crawling around under the dinette ASAP. After hearing about what y'all found I am not looking forward to adventuring in that mess.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 09-20-2017, 08:44 AM   #36
Half a Rivet Short
Hi
I would not classify any of this as a "must dig into right now" sort of thing. It's just another odd wrinkle in the "AS never does it the same way twice" story.
It would be nice if they could do a correct diagram of the trailer. I'm not holding my breath on that. Neither should any of those I promised those sort of corrections to back at work ... I'm retired ...
Old 09-21-2017, 06:49 PM   #37
Reads a lot
Uncle Bud, thanks for letting me know I don't have to deal with the nest of wires under the dinette right this moment. My calendar is bursting with chores until November, maybe December. Looks like I won't have time to play too much with my AS until March but I will be reading and watching and learning.
Lauri
Old 09-21-2017, 08:04 PM   #38
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
My firefly system under the dinette is also a rats nest of wires with the panel sitting on top. When I was at JC early Aug for warranty work the Tech mounted it to the floor so it does not fly around when underway.
I will test my power disconnect and mfg. date tomorrow and post.
Captain Hank is offline   Reply With Quote
Old 09-22-2017, 09:48 AM   #39
When I hit the store button with or without shore power connected everything cuts off. My trailer was built Nov 2016.
Old 09-22-2017, 10:14 AM   #40
Half a Rivet Short
Hi
A picture of the "official factory fix" might be really nice. (He says *after* you are back from the trailer ....)
Replace perfect ZipDee awning with power awning? Barretta2 Awnings 23 07-03-2017 06:45 AM
My Zipdee power awning beetlebob Awnings 22 05-09-2017 06:23 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1956 - 1965 Caravel 1 08-03-2008 07:40 PM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 06:20 AM
