Old 11-11-2009, 09:25 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Zipdee fabric roller sleeve
I am putting a Zipdee awning on my Tradewind from salvaged parts.
What is the correct position of the fabric awning sleeve? In other words, should the sleeve be riveted to the roller so that the seam that makes the sleeve is at 12 o'clock when the awining is fully open?
Anybody got a picture?
Old 11-11-2009, 09:34 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Save the riveting for last,mount the system,pull out and secure in open position,then install the rivets. Dave
easyride is offline   Reply With Quote
Old 11-11-2009, 10:35 AM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
That's what I figured. I assume when the sleeve is riveted on the plane of the awning fabric should be level with the top of the roller? Should the sleeve seam be at 12 o'clock or more like 10 o'clock position to reduce stress on the seam?
Old 11-11-2009, 12:54 PM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Does your awning fabric have the decorative fringe?
kennethowens is offline   Reply With Quote
Old 11-11-2009, 01:05 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Yes, mine has the decorative fringe or valance.
I think I found my answer on the Zipdee website. It looks like the awning seam is at about the 1- 2 o'clock position
Old 11-11-2009, 01:19 PM   #6
1975 Argosy 24
Malakoff , Texas
Correct...
I rebuilt two last summer.
The one's I worked on were the small
one's front and back. They have a
"funny little TUCK" where the pull-loop
is connected. If that little tuck is not there,
then it will roll-up crooked.
May I suggest small alum washers under your rivets
for added surface strenth.
Old 11-11-2009, 01:32 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by kennethowens View Post
Correct...
I was going to rivet the pull loop to the center of the inside of the roller. Can you post of photo of the ""funny little TUCK"".
I was considering using belly pan rivets with big heads to avoid ripping through the fabric.
Old 11-11-2009, 02:03 PM   #8
1975 Argosy 24
Malakoff , Texas
I am at work now and can't get the photo till
later.
The tuck is about 5/8" under the pull strap. It bonds
the large area of the fabric to the strap. The two folds
going away from the tuck distribute the force of the pull
from the strap.
I wish I had a photo for you...the small one's I
replaced were old and original.
Visit later
Old 11-11-2009, 03:16 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
The tuck is about 5/8" under the pull strap. It bonds the large area of the fabric to the strap. The two folds
from the strap.
There was sort of a funny little tuck on the original strap, kind of a folded over sewn end. I'm not sure if that is what you are referring to or not. I talked to Zipdee and they said just rivet the strap to the roller.
Old 11-12-2009, 07:49 AM   #10
1975 Argosy 24
Malakoff , Texas
Awning_Tuck
The photo isn't very good.
Old 11-15-2009, 08:43 PM   #11
The PO had the ZipDee awnings on our 1979 re-sewn at some point (they used thin thread and the streetside was put back on the tube upside down??). We ended up removing the front, rear and streetside to fix some issues. We re-sewed the streetside seams, replaced the insert that fits into the aluminum slat and re-made the pulldown strap (was torn in 2). To re-attach the pulldown strap, we used 2 rivets with large washers as Kenneth suggested. Our straps riveted directly onto the roller tube, just on the trailer side of the flap but not into the flap. The original? mount on our curbside, the strap rivets are through the flap making it sit out in the center. One day I will remove and re-mount so it isn't on the flap.
Argosy painted with a roller. boatdoc Clearcoat, Exterior Paint & Trim 32 03-21-2017 10:06 PM
Roller weight LI Pets Awnings 4 10-26-2009 09:20 AM
Roller Blinds HankO Upholstery, Blinds, Walls & Interior Finishes 4 09-22-2009 08:08 PM
Best way to hold roller shades bgarrison Upholstery, Blinds, Walls & Interior Finishes 8 04-07-2009 05:57 PM
Repair/Replace ZipDee Chair Fabric???? Tammy Upholstery, Blinds, Walls & Interior Finishes 3 08-01-2004 02:27 PM
