Old 12-13-2005, 02:29 PM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
ZipDee DIY
I have wanted to get a new ZipDee awning for my 75 Tradewind since I got it. The trailer has the mounting rail, but nothing else. After watching the final episode of the DIY Airstream series, the instalation looked fairly easy. Has anyone on the forum installed the awning and if so, did you order it from ZipDee direct? The dealer wants about $240 for the install and they are 2 hours away (Tucson, AZ).
Richard
Old 12-13-2005, 04:33 PM   #2
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Awning install
I installed a new rail and awning on my 1973 Argosy without help! Easy install, just follow directions and get HELPER.
Make sure the locking pins on the arms are LOCKED.
If not you will have problems.
Don
Gunnyusmc is offline   Reply With Quote
Old 12-13-2005, 05:13 PM   #3
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
The installation is fairly straightforward, but you will need hand tools such as a drill and bits, and a pop rivet gun. This is not a job to be done alone. You need a second person and it goes pretty smoothly. I used the original awning rail that hung my vintage pole type awning for the install on my overlander and we installed a new rail on my friends overlander. Both turned out great. Try to use a rivet hole finder if you install a new rail so you can use the existing holes from your old rail. Good luck.
Mark
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 12-13-2005, 07:46 PM   #4
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I installed the awning on our '64 Overlander. It's not hard as long as you have a helper and the right tools, which you probably already have. The instructions were good. The original mounting rail fit the new awning. I ordered through Inland RV and ZipDee shipped it to my inlaws where I did the installation.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 04-11-2006, 11:21 AM   #5
weblog moderator
CruiserBob's Avatar
1966 22' Safari
Oceanside , California
I have been searching for the stock awning for my 66 Safari. It's track is 12' long. Anybody got any pointers?
Bob Kiger
Oceanside, CA
1966 Safari
Bob Kiger aka Cruiser Bob
Maui > Oceanside, California
CruiserBob is offline   Reply With Quote
Old 04-11-2006, 01:02 PM   #6
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Bob Kiger
Oceanside, CA
1966 Safari
There was no "Stock" awning. It was mostly a dealer installed option at the time, and definitely not a a Zipdee. I have seen old Carefree's and some strange contraption in a box up on the rail that has poles that fold out. There also was a "bag" awning with poles and you had to put it on the coach and off each time. I think. I wasn't born when ours was made!
As for getting a zipdee, yes, you need to verify just how long to get the awning, probably by asking Andy at Inland or AS customer service.
John
AYRSTRM2 is offline   Reply With Quote
Old 04-11-2006, 03:24 PM   #7
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
John
I called ZipDee a few weeks ago to get a price for an Awning and as I didn´t know the length needed I just told them which Trailer we have. They told me which length we need and gave me the same price as Andi at InlandRV (both prices for the Awning without shipping!). So just call ZipDee or Andi, they´ll both be very helpfull...
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 04-11-2006, 04:46 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Hey folks,
If you need help on the East Coast, I'm also a Zip-Dee dealer . Awning installation is not rocket science and Zip-Dee provides very clear instructions. You just need a second (or 3rd person for awnings over 20') to help slide it in to the awning rail and hold dit while you secure the arms to the coach.
Old 04-28-2006, 10:27 PM   #9
1970 31' Sovereign
palm springs , California
can't find evidence of awning at all!
Hey all
I'm thinking I should order the awning fast since it sounds like it takes a while to get...However i don't have anything on my trailer that would indicate a previous awning...There is no "rail" So how do I put one on? Thanks
happydaze is offline   Reply With Quote
Old 04-29-2006, 06:30 AM   #10
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Originally Posted by happydaze
Hey all
I had always thought that the rail was standard equipment. It is a split metal tube that runs from the back of the front end cap to the front of the back end cap about where the roof meets the wall panels. The tube is about 3/8" in diameter, make sure that you either do or don't have this. If you don't, then maybe it was damaged and removed. There for rivets would be filling the original rivet holes.
As for installing one, someone else will have to guide you, but good luck!
John
Visit my Camping Blog!
Old 04-29-2006, 08:21 AM   #11
lewster's Avatar
Awning Rails
Some have 'em.....some don't. It's not a problem to install one and Zip Dee will include it in the shipping tube if requested. You can call them for your length spec's as they maintain a file on every Airstream that they made an awning for since they became the preferred OEM awning supplier to A/S.
AS restore of DIY TV xploretx General Repair Forum 13 05-28-2009 04:17 PM
diy show on Airstream restoration tracker Airstream "In the News" 7 11-28-2005 11:22 AM
DIY Network Show. ssww Our Community 7 11-27-2005 01:58 PM
DIY airing restoration of 1970 Airstream Minnie's Mate Our Community 9 10-17-2005 05:19 PM
