Old 05-05-2016, 11:07 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
ZipDee awning release replacement?
Recently had my awning release break off. The piece you pull down to roll the awning out or push in to put awning in. Anyone know where I can purchase a replacement piece? Also any idea on how to replace it? Thanks fellow streamers.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 05-06-2016, 05:29 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Is this part at the end of the roller? Photo would help. It sounds like the part you are talking about is the "Z lock". Most Zipdees don't have one. You need to get it from Zipdee. They are usually installed at the side of the roller not spring loaded. (In my case I have one on each end. Working on the spring loaded side requires unwinding the spring which can hurt if you are not careful) Pretty easy to replace. As I remember what I did was: extend the awning, tie off the awning so it does not retract, use a brace such as a stepladder to support the roller, remove the nut and bolt that holds the roller to the main arm, drill out the rivets that hold the Z Lock on with a 1/8" drill. Reverse the procedure for installing your new Z lock.
FYI/ the lever on one of mine broke off years ago. I used epoxy putty to do a "temporary" repair. Still works.
It can also be replaced with a non locking end cap, also from Zipdee.
Old 05-06-2016, 09:50 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
If you are talking about the strap with a loop that matches the awning you can get it from Zip Dee directly for about $25. They come in direct replacement colors and have installation items and instructions included. I replaced the ones on our '76 and have an extra one "just in case".
Dennis
dennis3751 is offline   Reply With Quote
Old 05-06-2016, 09:53 AM   #4
1965 26' Overlander
Images: 34
Name:	ImageUploadedByAirstream Forums1462549978.686990.jpg
Here's the piece
WBCCI# 2578
Four Corners Unit
Old 05-06-2016, 10:04 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
That is the Z lock, although it looks like an older one. I may have an extra new one I can sell if you are interested. Send m a PM.
Old 05-06-2016, 11:10 PM   #6
1965 26' Overlander
Images: 34
Thanks all! Called ZipDee and they shipped me a repair kit for around $25.
WBCCI# 2578
Four Corners Unit
Awning replacement: A&E to ZipDee ? Janet H General Repair Forum 8 11-27-2012 04:43 PM
Pressure Release Valve - Replacement lebolewis Fresh Water Systems 14 01-04-2010 11:17 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1965 Caravel 1 08-03-2008 06:40 PM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 05:20 AM
