Some of them didn't have power switches, just hit the "extend" or "retract" button. If yours is one that has the switch, it is located on the main control panel when you enter the trailer, on your left, at the end of the galley counter by the door.
Has anyone manually cranked the power awning back on a 2017 Classic or similar set up? Can I simply turn the above referenced power switch off & then retract with the manual crack Airstream supplied? Thanks guys, appreciate the input--Brad
You actually should have been supplied with some wires that will allow you to by-pass the circuit and switch, wiring directly to the battery and retract in that manner.
There are instructions running around somewhere on how to plug the power cord into the motors. There also is a YouTube video showing some poor soul doing it.
Yes Uncle Bob, I saw that video too which lead me to believe there was a switch on the circuit panel. Just trying to go out on the road prepared should/when the need arises. I'll post a good definitive answer once I get it. Know in the meantime I very much appreciate all of your suggestions/help.
