Old 03-16-2011, 01:48 PM   #1
aname4me's Avatar
1988 25' Excella
Thunder Bay , Ontario
Zip Dee Z-lock lever is stuck
I bought my 1988 Excella in the Fall. I live in the Northern Ontario and Spring is finally coming. I was trying to open the Awning today. I have never done this before. I can't seem to pull the Zip Dee Z-lock lever down. I REALLY don't want to break it. I can't say when it was last opened.
Do I "lube it" or pull really hard?
I did unscrew the Clamp Wheel, but it was very stuff. I had to use Channel Lock pliers.
Like I said.... I REALLY don't want to break it.
aname4me is offline   Reply With Quote
Old 03-16-2011, 01:55 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Lube it for sure before you pull really hard. Try a dry spray lubricant. It may be bound up, and sometimes wiggling the places that are suppose to slide will help more than brute force.
newroswell is offline   Reply With Quote
Old 03-16-2011, 02:25 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I suspect you broke a gear tooth. Wiggle the bugger back and forth and if you are lucky you can dislodge the broken tooth. If you have a broken tooth it will probably get stuck again. You can get a new lease on life by taking the Z lock apart and rotating the gear to expose new teeth. Whatever you do be really, really careful if the roller spring is tensioned. It's a bone breaker.
Old 03-16-2011, 02:43 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Call Zip Dee. They are great to help out on the phone.
Old 03-17-2011, 06:13 AM   #5
aname4me's Avatar
1988 25' Excella
Success.... I sprayed it with a oil twice yesterday and again this morning, then several minutes of back and forth tugging.
Thanks for your advice. It is comforting to know there is a help network out there.
stuck, zip dee
KT lock question Bonitafarms Doors & Locks 10 06-28-2019 12:57 PM
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
Help on door lock 1977 as land yacht sovereign harrodone Doors & Locks 7 04-23-2011 09:37 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
'75 Trade Wind door and lock Breadbug Doors & Locks 2 01-31-2011 09:20 PM
