Old 04-27-2016, 06:05 PM   #43
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AWCHIEF View Post
I was thanking the same as you. The sun screen room when properly installed seems to really beef up the awning. I have only used my screen room a couple of times because it is such a PITA to put up and take down.
One of the main things a screen room does is it provides a windbreak to reduce uplift forces on the awning fabric. With the screen walls in place, the wind can still suck the fabric up through a venturi effect, but it's harder for wind to get underneath to blow the fabric up directly.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-27-2016, 07:00 PM   #44
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Agree, the sun room is designed to add water to the bottoms to hold it down. No idea how much but I would guess a couple of hundred pounds when full.
MICHAEL
Old 04-27-2016, 07:30 PM   #45
1972 27' Overlander
Denver , North Carolina
I have the original 1972 awnings on my Overlander. Other than doing something very stupid - like leaving it deployed in the rain, this thing has worked flawlessly. Back to the issue, I bent the main tube and replaced it myself using the ladder method they describe. It's very important not to wind the rear tension arm too tightly. I remember the formula to be length plus seven equals number of turns. Then be very careful as you are now holding a propellor. Either way, it's doable but not very much fun. All three of my zip dees work fine.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-27-2016, 07:36 PM   #46
about 150 pounds for the 8-foot tubes for each end wall, and about 225 pounds for the 12-foot tube for the long front wall, if you fill them as full as possible. In actual practice the fill ports aren't well located, and you'd be lucky to get half of that weight of water in them.
I bought some of those Zip-Dee tubes for my Fiamma Privacy Room for my Interstate, so I could use the Privacy Room without having to drive stakesó it's hard to drive stakes for a screen room when you're parked on pavement. I eventually got rid of the Privacy Room, though. More trouble than it's worth for a solo traveler, especially if you're trying to take it down in order to take in the awning before a storm hits. Can you say "Chinese Fire Drill"?
Old 04-27-2016, 07:45 PM   #47
AWCHIEF's Avatar
Images: 33
Agree, I actually find it more trouble than it is worth. If the bugs are so bad that bug killer or my electric repellant does not work I go inside. I do have a sun shade that I made and use it all the time. It attaches to the same snaps as the sun room.
MICHAEL
Old 04-27-2016, 08:08 PM   #48
CRH
1995 25' Excella
xxxxx , xxxxxx
You can't use it in the rain?
CRH is offline   Reply With Quote
Old 04-27-2016, 08:23 PM   #49
AWCHIEF's Avatar
Images: 33
As long as the wind is not blowing too hard I leave mine up in the rain. Love sitting outside when it is raining.
MICHAEL
Old 04-27-2016, 08:25 PM   #50
CRH
1995 25' Excella
xxxxx , xxxxxx
I also leave mine open during showers so I can sit outside. I thought maybe I was doing it wrong....lol
Old 04-27-2016, 08:39 PM   #51
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I love watching a rain storm under the awning. Just gotta remember to angle the awning so rain doesn't puddle up and of course, if it's windy, roll it up and hop in the trailer!
SteveSueMac is online now   Reply With Quote
Old 04-27-2016, 08:53 PM   #52
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by Lumatic View Post
From my experience where you have to be real careful is in storing the awning placing the rafter arm hook on the storage pins. With all the weight and leverage of the whole awning it is easy to bend the bottom curved end of the main awning arm. As an alternative attach the rafter arm to the storage pin after the awning is rolled up
Thanks for mentioning this! I'll try putting the arms on the pins after the awning is retracted. The last time we used our awning we bent that bottom curved piece on the rear arm. The awning is 40 years old and we've used it a number of times in the 7 years we've had the trailer with no problems prior to this. I'm not sure what we did different this time. I made a new piece and bent it to match the front one. $3 in materials and an excuse to use my milling machine. Not knowing what caused this one to bend, I was worried that if I bought a new one I'd bend that one too.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 04-27-2016, 09:36 PM   #53
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
Angry Zipdee
Originally Posted by robi View Post
Sorry, it was protagonist. I guess I am feeling a little antagonistic after spending more money and time on my zip dee awning:}
I concur with Robi. WATCHED the video 6-7 x. OPENS OK. Closing is a disgusting hassle every time. The back brace is the culprit each time. Tried silicone, I guess
I should have used a lot more.
You would expect a better product considering how much an AS COSTS, ,3 to 4 times more than a JC Eagle.
Have not used it the last 6 weeks on our last trip. Quality is missing!
One of the hooks on the front brace broke at our orientation at the dealer.
I love towing my 2015, handling and gas saving is great.
The Carefree awning on my 2012 SOB, electric, was a pleasure to use with 1 finger.
1Boyscout is offline   Reply With Quote
Old 04-28-2016, 03:34 AM   #54
1972 27' Overlander
CRH - I don't leave it deployed when it's raining - I am perhaps a tad cautious. Once bitten, etc.
Old 04-28-2016, 10:16 AM   #55
2016 30' Flying Cloud
Oviedo , Florida
I have been using Zipdee awnings on 2 different Airstreams over the past 12 years. I'm rather amazed at the intensity of the complaints in this thread - I have had zero issues operating both awnings. It's hard to imagine having so much trouble after watching the various instruction videos.
I have no magic suggestions, I'm just baffled.
Keith
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 04-28-2016, 10:34 AM   #56
I'm sure not everyone has seen those instructional videos. The elderly folks I assisted with their Zip-Dee a couple of weeks ago certainly hadn'tó and neither had I, until later on this very thread. They've had their Airstream since 2005 when it was brand new, and in all that time, apparently no one ever showed them the right way to do it. They did it the way they figured out for themselves, and that's how they directed me when I helped. It required a stepstool and brute force and was done in the wrong sequence. And they didn't use that rod shown on the videos, though I think they had one and just didn't know what it was for. Or maybe they knew how to use the rod but their hands shook too much to use it effectively.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
Why is our Zip Dee so Droopy?! grsdlightnin Awnings 2 08-30-2008 08:51 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
