Old 04-27-2016, 08:13 AM   #29
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by ROBERT CROSS View Post
The Zipdee guy makes it look easy. I use a couple of tricks he shows to deploy the awning which may it easy. From my experience where you have to be real careful is in storing the awning placing the rafter arm hook on the storage pins. With all the weight and leverage of the whole awning it is easy to bend the bottom curved end of the main awning arm. As an alternative attach the rafter arm to the storage pin after the awning is rolled up
Old 04-27-2016, 08:32 AM   #30
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by SteveSueMac View Post
And instructions on lubricating
http://youtu.be/fMDV3qkgntw
Thanks for the link Steve. I have never lubricated mine at all. So I'm guessing I might be a little over-due!.......
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-27-2016, 08:39 AM   #31
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I've forgotten more that I'm currently aware of....
It wasn't really a ZipDee problem it was how it was installed that made it hard to operate.
The rear arm was out of plumb about 3". Had to remove the lower bracket and re-install so the arm was straight. Replaced phillips with hex and plenty of SikaSeal
Be aware that ZD is replacing the bolt and collar where the hook arm sits. The collar does not seem to be big enough to separate the hook from the other arm. Be aware that the installation could have been made by anyone including the PO.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-27-2016, 11:22 AM   #32
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Funny thing here;
Nobody has mentioned using some sort of ty down straps or lines from the roller to the ground.
These are attached to screw anchors in the ground and adjusted snug to support the awning from windy gusty conditions.
I just use a couple of ratchet straps adjusted snug.
It works!😆
MelGoddard is offline   Reply With Quote
Old 04-27-2016, 11:28 AM   #33
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Concerns about the Zip Dee awning are what caused us to forgo that awning in favor of ordering a custom awning from Vintage Trailer Supply. We chose a scalloped edge in a stripe and colors that complemented our color scheme, and ordered a length that was specific to our needs. Awning, poles, etc. all came to right at $500. Yes, the awning must be slid along a rail, then put up using posts, but we have been able to use it just about every time we wanted to. (Exceptions being no ground or structure - such as a picnic table - to attach it to.) You quickly become proficient at putting it up, and it looks wonderful next to the trailer.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 04-27-2016, 11:41 AM   #34
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
I used my ZipDee for 18 years on my first AS. Yep, occasionally had to kind of bend the bars back some. But I have never seen another brand and material out there last effectively this long. When I sold her, the awning was still functionally working as designed and looked good too. I guess some improvements could be made but I know of know other competitor out there with the degree in quality materials used.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 04-27-2016, 12:54 PM   #35
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Not to engage in any schadenfreude here, but I thought I was such a cheap dummy when I went with a Dometic awning. I managed to bend the arms a few times, and pull the rivets out of the top mount. I used a bunch of Boeshield T-9 dry lube (it's what sailors use on the mast track, to ease the sail going up-and-down) and it seems to be much better.
The Zip Dee looks to require more muscles and operator height than my Dometic. I wound up going with a thick aluminum mounting plate held down with many, many rivets that the actual mounting plate of the arm is fastened to.
SuzyHomemakr is offline   Reply With Quote
Old 04-27-2016, 01:01 PM   #36
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
In our case the PO would have been JC, there are still a few things they have a hard time getting rite.....
FWIW...the zip tie is to prevent pre-mature arm deployment under adverse road conditions...once was enough.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-27-2016, 01:18 PM   #37
Lumatic's Avatar
1993 34' Excella
Images: 16
IMHO height is not an issue to deploy the awning as it is first deployed at it's lowest level. Where muscle is most involved is lifting the awning from the lowest position to it's operating level, but it's not a real strength move.
Old 04-27-2016, 02:11 PM   #38
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Back to the original comment, I'd never leave our awning out over night, to start. Then it sounds like his spring tension is too tight. On our "10 FC I immediately unwound the spring 4 full thorns so it will not retract by it self. This saves tension on the rear arm as well as keeping the awning from getting away from me. I replaced the awning storage pins with larger diameter ones to keep the arm claw from climbing up on the inner part of the stock pin and breaking. I'd gone through a couple of claws over the years. I also added a second storage hook to the patio side awning as well as the street side one. Finally, I added stock security straps and hooks to the ends of the street side awning because the single one in the center that came with the trailer did nothing to keep the awning from tipping in even a light wind. I've mentioned these additions to Zip Dee and they were not receptive.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 04-27-2016, 02:18 PM   #39
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Originally Posted by MelGoddard View Post
Funny thing here;
It works!😆
We accomplish the same thing with our Zip Dee sun screen accessory. We bungee it to the ground to provide some give to the awning, should a wind slam into it.
Antique Pedaler
Old 04-27-2016, 03:59 PM   #40
Lumatic's Avatar
1993 34' Excella
Images: 16
I agree that is a good practice, but sometimes I get a little lazy.
Old 04-27-2016, 04:01 PM   #41
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
FWIW...the zip tie is to prevent pre-mature arm deployment under adverse road conditions...once was enough.:
For re-usability, try using a Velcro strap. ZipDee reps hands out red ones with their logos. Got mine when they installed optional rear and road side awnings at their factory.
Name:   ImageUploadedByAirstream Forums1461794333.836336.jpg
Name:   ImageUploadedByAirstream Forums1461794441.739662.jpg
Greg
greghoro is offline   Reply With Quote
Old 04-27-2016, 05:34 PM   #42
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I mentioned that to the ZD rep at the Florida State Rally after he said do not under any circumstances tie the awning down when opened. He rolled his eyes and had nothing else to add, keeping to the party line like a good employee.
I was thanking the same as you. The sun screen room when properly installed seems to really beef up the awning. I have only used my screen room a couple of times because it is such a PITA to put up and take down.
MICHAEL
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
Why is our Zip Dee so Droopy?! grsdlightnin Awnings 2 08-30-2008 08:51 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
