Old 09-14-2018, 12:39 PM   #21
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Street Side Awning Installation 25'Safari SE
Dwight,
A little off topic here, but I found some old pics of the aftermarket installation on my 25' Safari.
I couldn't upload pics on the PM so I am sending them to you this way.
On one of the pics you can see the one of the outside sun screens attached.
I had them made for all the windows, except for the front. Very helpful to cut the heat especially the rear wrap around, which had no window tinting from the factory.
Please be aware even after you install some or all of the awnings, any temperatures above 100 degress the difference is minimal. The single air conditioner simply cannot keep up. Good Luck
Hugh
ID:	322507   Click image for larger version
zapper is offline   Reply With Quote
Old 09-14-2018, 01:53 PM   #22
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
What am I seeing in photo 3. It appears the awning fabric is installed way to high, and is not protected by the aluminum cover. If this is the case, that material isnt going to be very secure, nor last too long. The awning fabric should never be seen while in the rolled up, store position. Am I not seeing this properly?
Old 09-14-2018, 02:00 PM   #23
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I agree, Atomic. Looks like they installed the awning on the rain drip rail.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-14-2018, 02:06 PM   #24
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Yep that’s wrong. Should look like this
ID:	322522   Click image for larger version
Old 09-14-2018, 02:13 PM   #25
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Wow, do you shine up your Airstream to work on it, or are you just showing off?
As fulltimers, mine is always in motion so no time to shine it up!
Old 09-14-2018, 02:31 PM   #26
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Ha. No just keep it washed and under cover.
Full time huh. Where you guys now and where you headed?
Old 09-14-2018, 02:35 PM   #27
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Wait. No his awning is correct. That’s a cover he had made to cover the two top windows. Very clever!
Old 09-14-2018, 04:24 PM   #28
1976 31' Sovereign
Oswego , Illinois
When I had zip-dee install anins on cub side road side and rear they were using silicone but I always have a tube of parbond aluminum color in AS for need, they stated did not no of it but used my awnings and they were impressed w/it, but silicone lots less money. I also have sikaflex but not handy to keep in AS as takes caulk gun resulting larger mass to stow, both tube and gun plus gets hard if not using for awhile results in loss of cash spent.
Old 09-14-2018, 08:26 PM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
GMFL,
We are chillin with friends at the Jersey shore. Doing the Naches Trace drive then down to Key West for a couple months.
We road school full time. Exploring the civil war next year... Gettysburg then Smithsonian in the summer . Whew....
Old 09-15-2018, 10:57 AM   #30
zapper's Avatar
Atomic, the fabric you see is a snap on removable black fabric sun screen that I had made to cover the outside of all the windows. Phoenix Valley sun. In this picture the screen is covering the two (I know it's the wrong term for them) elliptical port windows above the kitchen/lounge windows. Actually none of the awning fabric is showing underneath the metal awning protective shield. Didn't help much keeping the heat out but was installed correctly. :-)
Old 09-15-2018, 11:12 AM   #31
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Ok, now I understand what I'm seeing. Thanks!
Vintage Fusion - the story of our '69 AS Remodel monah 1959-69 Tradewind 255 09-08-2011 10:40 AM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
1970s era Zip Dee (Curved) Awning funkill Awnings 7 04-06-2011 11:16 AM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
