Old 05-12-2011, 07:32 PM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Another good source for butyl tape is industrial supply houses that sell caulking and other types of sealants. It is used extensively in the commercial/industrial building industry for sealing metal flashings. The chain in my area is Guaranteed Supply. I have also found it in some of the better stocked commercial lumber yards.
Aaron
WBCCI #XXXX AIR #2495
Old 05-12-2011, 07:36 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Well, Greg, now you know what you are looking for, and where to get it. If you have any problems, come back and ask, we'll happily tell you where to go...
Old 05-13-2011, 06:05 PM   #17
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
OK, BUTYL tape it is, and thanks for the advice to this newbie.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-11-2011, 07:01 PM   #18
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I thought I'd report back after going to the Zip Dee Awning factory with my daughter for her awning. Actually, I told her to report, but she's a busy mom & probably forgot! We dropped her Argosy Minuet off in the morning & showed them the Sikaflex that she wanted to be used for her install. After a few hours of shopping at Ikea & the mall, Zip Dee called her & said she was ready to go. When we got back, my daughter opened the door to the trailer & there was the tube of Sikaflex--unused..... I jumped up in the door to see what was used on the hardware & ---Gasp----it was clear silicone Well, there was a lack of communication between the installers & the man who checked us in, so they used what they always use & "what we've used for 30 plus years without any problems." I asked them to remove the hardware, wipe off the silicone, and replace it with Sikaflex. They didn't really think it was necessary, but I told them that my daughter spent a lot of money on it, it wasn't her mistake, and she would like to have the change made. They did all the changes--even had to run out to purchase a caulk gun to do it for her. We waited about an hour for it to be finished & she now has her beautiful custom color awning on her Minuet. Zip Dee has a very good customer service reputation, and it held up again! One thing that they forgot to install until we were there (and I'm glad they did so we could stop them) was a wheel on the door. They were going to put screws in the skin of the door for the wheel & said that they did with every install. So, if you don't want a wheel on your door, you had better specify that (strongly) before you drop it off at the Elk Grove Village, IL factory. So, the answer to the silicone question is "yes, they use silicone".
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-12-2011, 12:38 PM   #19
SailAS's Avatar
2007 25' Safari FB SE
Sugar Land , Texas
Thanks for the report. I decided against clear silicon and ordered 3 tubes of SikaFlex 241 in gray. I used one tube in installing my rear window awning and the Road side awning on a 25FB. It matches the gray caulking used on the original Patio Awning.
I must say that this stuff sets up quickly so if you use it on any install, you need to work quickly. Mine was "dry" in less than an hour when working at 90 degrees F and probably 70% humidity!!!
Dwight & Ellen + (the Beagles)
2011 F350 SRW King Ranch, 6.7L, 3.55 ELD, Ranchos, Hellwig w/ Reese Dual Cam & 1200# bars. 2007 Safari 25 FB SE (stock)
For Sale:2002 Excursion Ltd 4WD 7.3L; 3.73 LS; fully mod'ed
SailAS is offline   Reply With Quote
Old 06-12-2011, 12:39 PM   #20
SailAS's Avatar
Sugar Land , Texas
Oops. I meany Sikaflex 221 in gray.
Vintage Fusion - the story of our '69 AS Remodel monah 1959-69 Tradewind 255 09-08-2011 10:40 AM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
1970s era Zip Dee (Curved) Awning funkill Awnings 7 04-06-2011 11:16 AM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
