Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 07-05-2007, 09:27 AM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1972 27' Overlander
1977 23' Safari
Palmer Lake , Colorado-thinnest and highest state
Airstream Registry
Zip Dee upper bracket fix
The long Zip Dee on my Sovereign has seen better days. While removing the vista view windows I noticed that both the forward and aft upper brackets were loose. Since the rib and shell area under the brackets were accessible due to the other mods I was doing, I decided to strengthen the mounting area with doublers and a suitable shim on the exterior to match the new vista view window patches. Don't be confused by the photos--they are a combination of the forward and rear brackets, so they may appear reversed if you make them all one installation!
The original bracket mount and damage underneath:
Name:	IMG_7086 existing fitting-s.jpg
ID:	40599Click image for larger version
Name:	IMG_7088 enlarged hole-s.jpg
You can see how the skin is pulled away from the rib, here. Two of the new rivets in the vista view patch need to be drilled out to allow the new doublers to lie flat on the inside skin:
Name:	IMG_7089 pulled from stringer-s.jpg
Here's the total set of parts. The bracket, the shim under the bracket on the outside, two shims/doublers to equal the thickness of the rib flange, and then the inside doubler with three nut plates. The #10 aircraft screws that fit the existing holes in the bracket have a yield strength exceeding 1,000 lbs (thank you, Kip), so you could pick up the entire Sovereign on this pair of reinstalled brackets. The inside mounting plate and shims were fit to the existing holes by screwing the bracket in, which held everything in place, then match drilling the rivet holes.
Name:	IMG_7091 parts-s.jpg
One advantage of the nut plates is that I can remove the brackets and temporarily seal the holes using short screws--the outside shim would protect the skin from the screw heads. The outside shim and inside doublers were installed using Trempro 635 (same as the old Vulkem).
Name:	IMG_7217 final inside-s.jpg
ID:	40603Click image for larger version
Name:	IMG_7216 final fitting-s.jpg
This has been slowing me down for a couple of weeks--very glad to be on the move again!
This same repair can be done fairly easily even if you aren't modifying your vista view windows. It's only requires drilling out about 7-8 pop rivets to peel the skin back far enough to gain access to the inside of the shell (in skins without a vista view) and a few more if you have to release the vista view inside slide cover.
Zep
MindsEyePhoto AirstreamDoctor PygmyKayaker
Good judgment comes from experience, and often experience comes from bad judgment. ~Rita Mae Brown
Old 07-05-2007, 09:34 AM   #2
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Great job! I had trouble with the upper hanger on the rear side of my patio awning. I used JB Weld then drilled new holes. It didn't seem to work as the JB Weld split. I tried again but this time put JB Weld in the holes and on the base of the mount. It has held up fine over the last year. I like your idea better but I think I had a cabinet in the way I would have to remove.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-05-2007, 09:39 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 67
Airstream Registry
ZEP ~ When I installed the ZipDee on my 75 TW I had a problem with the Vista View and the upper bracket. I could have used the shim that you had under yours. Too bad that ZipDee does not provide that shim as an option. When I contacted ZipDee the tech suggested that I shim the upper bracket with gasket material. I would have needed many many layers of the material to fill the void.
I decided to remove some material from the upper bracket to allow the rest of the bracket to sit flat on the trailer skin. If I was to remove the windows I could always replace the bracket.
ID:	40605   Click image for larger version
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-05-2007, 09:46 AM   #4
1972 27' Overlander
1977 23' Safari
Airstream Registry
Richard,
Took me just a second to realize that wasn't just a piece of bent sheet metal in the right photo. Nice work hogging that bracket out.
One comment about shims--it's obvious that the installer on my Sovereign realized the importance to getting a tight-to-the-shell fit, because the round head rivets that would have been under the bracket are shaved off (not drilled out--shaved off). I'm not sure that you gain much by shaving the head off a driven rivet, maybe a little sheer strength. I think the rivets or screws through the bracket are the real strength in that spot.
Zep
Old 07-05-2007, 10:06 AM   #5
Phoenix , Arizona
Images: 67
Airstream Registry
I also took a little off the rivets to get a better fit. In the first picture the bracket is just sitting against the shell. A Dremel tool is a good investment.
Richard
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
awning bracket manley Awnings 2 08-22-2002 06:16 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
