Old 10-04-2007, 05:58 AM   #15
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Left mine up and level in the rain. Bent the support arm.
Tom
henw is offline   Reply With Quote
Old 10-04-2007, 06:53 AM   #16
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Heed your dealer's advice and roll it up if you're not around. EVEN AT NIGHT. Roll it up before the dew sets in just in case you move before having a chance to dry it out. Save yourself a painful expense in repair. Been there and done that. ZIP DEE never even included the tee shirt! Stupid me
HAPPY TRAILS
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 10-04-2007, 09:43 PM   #17
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I use the "Would I feel stupid" rule.
Pat
pmclemore is offline   Reply With Quote
Old 10-04-2007, 10:12 PM   #18
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
You have gotten a lot of good advice. Bottom line, an awning anchored to the side of a trailer is just about impossible to leave out and not incurr damage.
My friend who spends the winter in south texas does leave his out all the time. He uses a 2-3 inch nylon strap running the long way of the awning placed about a foot from the outside edge. Each end is then attached to a fairly heavy spring which then fastens to an anchor in the ground. He also used the clips from camping world to attach the side of the awning to the braces.
I almost never put mine out. Caravanned for 3 months this summer and it wasn't out once.
wingfoot321 is offline   Reply With Quote
Old 10-04-2007, 10:18 PM   #19
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Wind vs Rain
Wind is my biggest fear with the Zip Dee. Rain is not a problem if you keep the awning angled. During rain, I keep mine at the 4th hole on the front of the AS where the door is, and the 1st or 2nd hole at the rear. This gives a good angle to prevent water from pooling on the fabric and bending the arms.
I witnessed an SOB bend it's supports at Bullards Beach SP in Oregon last weekend by collecting water on the fabric. When the owner woke up, he must have had 50-75 gallons of water collected on the awning. One support arm remained straight....the other bent 90 degrees.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 10-05-2007, 06:10 AM   #20
1992 34' Excella
Punta Gorda, , Florida
Up or down? Is that a card game?
We've been in the mountains of Western NC since April. During that month, we had 70 MPH winds and of course the awning was up. After we cleaned up all the limbs that came down the awning went back out to cover our carpet and chairs and it's been out ever since. It's tied down big time and tilted when it rains or when we leave for the day.
FlaAirstream is offline   Reply With Quote
Old 10-05-2007, 07:47 AM   #21
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We leave ours out most of the time when camping. If it's really windy, we'll put it in. If there is any rain in the forcast, we will lower the side opposite the door by one notch. If we go away from the Airstream for any length of time, we will put the awning in.
SuEllyn & Brian McCabe
Old 10-05-2007, 08:37 AM   #22
jcanavera's Avatar
Fenton , Missouri
Images: 143
I bought one of these straps years ago after having an awning arm on an SOB bend on me from the stiff breezes coming off the ocean at a beach front campsite. I've not used it with the Zip Dee yet since the Zip Dee seems to handle wind much better than any awning I've had on my SOB trailers. I'll be down in Florida next month close to the ocean (first time with an Airstream) so I might end up using the strap there.
Normally my criteria for putting the awning away is winds and weather and where we are at. The Zip Dees when configured with the side arms in a non extended mode really are pretty stable. First if it rains when they are in this state, there is no possibility of water pooling so weight won't be a factor. Secondly when down like this, they don't present as much surface for wind to get under. In non thunderstorm rain situations at night, I may lower each side down quite a bit, and in the day lower the side towards the rear of the trailer.
Obviously if I'm gone on a day trip and there is any chance of a thunderstorm, I'll play it safe and roll the awning up.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-05-2007, 08:59 AM   #23
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
FWIW, I roll mine out and keep it out unless bad weather is either forecasted or being happening. It's been out in 20mph winds and has not had an issue, but I don't think I'd have it out with even slightly higher winds.
Old 11-17-2007, 03:37 PM   #24
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Better safe than sorry!
I was aware of most the safety concerns for awning use, but one sunny day I left it up to do some local touring. But when I returned to the camp site, I found that a small cloud burst had filled the awning with 40-50 gals. of water and bent one support arm and the awning tube. Yes, it was tied down and had one arm tilted down but not enough to prevent collecting a lot of water.
I've straighten the arm and some of the tube, but now the awning is always up unless I'm under it. That should be in the operators manual because of all the noted concerns in this forum. If your at your trailer, you can control what happen to the awning, but if your not, it should be stored. End of story!!
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Old 11-17-2007, 08:12 PM   #25
Alumination
2005 28' Safari
Hillsboro , Texas
Send a message via MSN to njoysrvin
follow Overlander63 .....wish I had that advice the 2 times our awnings got messed up
njoysrvin is offline   Reply With Quote
Zip Dee Awning Chitown AirStreamers Awnings 14 06-09-2011 03:11 PM
Zip Dee Inland RV Center, In Commercial Listings 0 08-27-2007 10:06 AM
Zip Dee shinola345 Awnings 3 07-19-2006 10:51 AM
Zip Dee Inland RV Center, In Commercial Listings 1 07-13-2006 03:31 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
