Old 07-16-2017, 12:44 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Zip dee unlock thingy
I don't have the extension rod that unlocks the awning from the Argosy. It's a simple aluminum rod about 4 feet long, where can I get a replacement?
I'm in Seattle.
DanClick image for larger version
Dan S is offline   Reply With Quote
Old 07-16-2017, 12:59 PM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I would just call Zip Dee and have them UPS it to you. They are real good people to deal with.
Gregsch is offline   Reply With Quote
Old 07-16-2017, 02:14 PM   #3
1976 31' Sovereign
Oswego , Illinois
I never use rod scratched AS when slipped also can't get tight enough. Just do as I and others do use 2 step stool or as example one from amazon that is plastic will hold over 200 lbs. snaps open and close folds flat fits in closet. Can get wheel tight with out chance of coming loose plus much easier. You can also pur. alum. rod bend el on one end. some also use small fold flat ladder.
Old 07-16-2017, 02:36 PM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I use a 5 gal bucket for a ladder to reach the front, entry steps will access the back one.
Some Airstream dealers carry the awning wand in stock.
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 07-16-2017, 03:39 PM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I bought a small, foldable aluminum step from Harbor Freight. It holds up 350 lbs and folds small enough to stow away in a small space. I use it to step on and get just enough height to unscrew or tighten the wheels that hold the awning in place by hand. Good luck!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-16-2017, 03:40 PM   #6
.... and here is the link:
https://www.harborfreight.com/step-s...orm-66911.html
Old 07-16-2017, 05:10 PM   #7
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
Puller
I too never use it for ulocking the round knob. I also use a ladder. I do use one for pulling out the awning strap. You can buy I think it is a king pin puller fron most local truck stops. Mine is aluminum, Airstream blue and does the job. I actually cut it a little shorter and re-bent the end so it fits in my storage behind the stove. It also has a handle on the end you hold.
Hiwheel Joe is offline   Reply With Quote
Old 07-17-2017, 07:04 AM   #8
1976 31' Sovereign
Oswego , Illinois
Smile
King pin puller is excellent for pulling strap to extend awning.
Old 07-17-2017, 07:26 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I'm in Seattle.
DanAttachment 289627
http://www.awningsbyzipdee.com/washington.html
Alan
Old 07-17-2017, 12:39 PM   #10
Thumper
elstunr's Avatar
2002 19' Bambi
Colorado Springs , Colorado
Send a message via Skype™ to elstunr
I ordered mine from Amazon:
Ron & Michelle Elstun
Colorado Springs, Colorado
https://sites.google.com/site/elstunbambi
elstunr is offline   Reply With Quote
Old 07-17-2017, 12:45 PM   #11
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
The place in the Seattle area to buy metal goods in Online Metals, at the south end of the Ballard Bridge:
http://www.onlinemetals.com/merchant...195&top_cat=60
4 ft of 0.25 inch Al rod is all of $1.32.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 07-17-2017, 01:18 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Never scratched Mjolnir using the ZipDee deploy tool. I rounded the sharp corners to help minimize potential.
Get a stout folding aluminum ladder.. like they mention above. Less likely to tip over.
One of the release tools are ok... but too heavy which may make it easier to damage trailer skin. But it is strong enough!!
Old 07-17-2017, 02:09 PM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The Zip Dee tool is the same tool as any awning rod.
Should be readily available at any RV dealer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 07-17-2017, 02:53 PM   #14
2017 27' International
Sioux Falls , South Dakota
Interesting to read the comments about scratching the Airstream. The Zip-Dee pull rod that came with my 2017 Airstream has thick plastic coverings on both ends, so it can't scratch. Guess Zip-Dee got smart. :-)
Paprika is online now   Reply With Quote
Zip Dee Lock/Unlock 345bill Awnings 14 04-22-2017 05:02 PM
Help! Door Won't Unlock! 66Overlander Doors & Locks 12 02-26-2013 11:38 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 09:12 PM
Help, I can't unlock my door, Any ideas? rschulz Doors & Locks 20 12-18-2006 03:43 PM
