Old 05-18-2013, 07:56 PM   #1
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Zip-Dee Travel Latch - HELP!
We installed our new Zip-Dee awning today. Everything went fairly ok until I got the travel latch. It has me stymied...
In reading the directions, the hook piece that attaches to the awning metal cover should be screwed to the first section of the cover. But the first section of the cover is mostly under the awning and sitting next to the trailer skin. There’s not enough to it exposed to actually mount the hook to.
If I hold the hook in the correct position on the cover so it can latch into the eye that mounts on the trailer, the screw for the hook lines up exactly dead center of the hinge between the first and second metal sections of the cover. I doubt putting the screw through the hinge is a good idea.
If I move the hook up a bit onto the second section of the metal cover so the screw will clear the hinge, then it will not engage the eye of the latch unless I raise the latch up off the trailer about 1/4” with spacers.
Does anyone have a picture of their Zip-Dee travel latch installed on their awning that they can post? I’d love to see how others are installed before installing ours.
Chris
Old 05-19-2013, 07:56 AM   #2
Minno's Avatar
1972 31' Sovereign
One more question - why install it at the rear of the awning instead of the front?
Chris
Old 05-19-2013, 08:05 AM   #3
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I unroll the awning about a foot to get to the travel hook and nut. I have them at both ends......extra precaution.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 05-19-2013, 08:28 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Chris
From what you are asking, this might be what you are looking for. It looks as if the hook were mounted vertical, it would be dead center on the hinge between sections 1 & 2. Positioned offset, it then can be mounted on the slat.
No reason comes to mind as why they recommend mounting it towards the rear end of the awning other than the spring mechanism is on that end as I recall.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-19-2013, 10:01 AM   #5
Minno's Avatar
1972 31' Sovereign
Thank you, thank you, thank you! Exactly the picture Chris needed, Silver Goose! Yes, he was trying to get the hook vertical and it wasn't making sense. Antique Peddler, your answer makes sense too. We are thinking about 2 latches as well. This is an investment we definitely don't want to have to repeat!
Kay
Old 05-20-2013, 08:20 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Why not call ZipDee? They are always glad to talk with customers.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-20-2013, 10:42 AM   #7
Minno's Avatar
1972 31' Sovereign
It was Saturday... I would have called this morning if no-one responded.
Chris
Old 05-20-2013, 12:36 PM   #8
Ready-to-Travel
pmclemore's Avatar
Sorry - I should have observed that Silver Goose provided just what you needed and timely too. Just wanted to encourage you to call them. Looks like another happy ending.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 05-23-2013, 06:04 PM   #9
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
That's interesting. Mine came on the AS with 2 latches. Wonder why the add on version only has one?? I wouldn't trust it with just one. In fact I found some white velcro ribbon inside and I use it around the forward braces just in case the latch were to come loose. I think the latches are poorly designed. After almost 1 1/2 years of use I can never get the awning to roll up tight enough to latch. I aways have to use a step stool to reach up and push it by hand. If I let it roll up fast it doesn't even go into the cover all the way.
I notice that on the higher level Airstreams (I have the basic Sport model) they use a locking wheel mechanism instead of a hook. I wonder if those can be retrofitted to mine. Guess I should call Zip Dee when I get back from my Memorial Day weekend camping trip.
Rich of SCal is offline   Reply With Quote
Old 05-27-2013, 06:08 PM   #10
Minno's Avatar
1972 31' Sovereign
Ours came with 2 locking wheels (one front and one back) and 1 latch. We will add another latch for peace of mind. We don't think the locking wheels are really very secure and we're using a step stool to manually snug them down instead of trying to do it with the wand from the ground.
Rich, sounds like maybe your awning isn't tensioned enough. According to the directions we followed to install ours, it should be tensioned so that the awning will roll up after being started by hand for about 1 foot. It took a few tries with 3 of us to get it tensioned correctly, but the 21 ft awning rolls up easily now with just a push of my hand.
Kay
Old 05-28-2013, 12:20 PM   #11
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The locking wheels are the primary lock for the awning. Everything else is a backup. They didn't even install the backup measures until the 90s or later; my parents' '87 has nothing other than the wheels, and my main awning only has the additional cam lock that prevents it from rolling, no hook lock at all. The one streetside awning has a hook lock on it - apparently that's recommended for those awnings over a certain length.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-28-2013, 12:36 PM   #12
2012 16' Sport
Mino, thats what I was thinking, that it needs tensioning. I will have to look up how to do that since it was already installed by the factory.
Skater, not all zip dees have locking wheels. Mine only came with the 2 latches and that almost worthless aluminum pole that bends like spaghetti every time I use it. I was pleased to see an ad in the latest AS Life advertising a retro kit to modify zip dees and fit a 12 volt electric extender/retractor. It's sold by zip dee. I am going to check it out. Might save a lot of frustration if it doesn't cost too big a fortune.
Old 05-28-2013, 07:39 PM   #13
Mountain High
2005 ford's Avatar
1990 32' Excella
Adirondack Mountains , New York
Try drilling a small hole through the hook and when it's latched slip a latch pin through the hole and the hook can't come out.
2005 ford is offline   Reply With Quote
Old 05-31-2013, 07:52 AM   #14
StPierre's Avatar
1965 22' Safari
Rescue , California
Minno did you install travel latch yet ? I just installed my awning on my 65 Safari and have the same problem with the latch placement. Can you post picture .Thanks for the help
The St Pierre's
StPierre is offline   Reply With Quote
