If the center came out, I suspect it was because you did not push on the arm to engage the ratchet and spring. You must also do this with the side arms. The best way to understand this is to watch the video.
Pat
Somebody, please, point me to the road.
One of my travel latches fell off on our trip to Bellville, Texas this weekend. Called Holiday World to try to order one but they never called me back.
Tom Taroni
Call zip-dee they will answer ph. & promptly ship latch to you. Bill
A note about the Zip Dee Traveling Latches. Zip Dee ships Loctite with each latch to Airstream and also when you order a replacement. Airstream does not apply the Loctite. I would suggest doing it yourself so you don't have to order replacements.
