Old 06-10-2015, 01:31 PM   #1
Fort Worth , Texas
Zip Dee Support Hook Broke What To Do?
The hook that helps support my Zip Dee awning broke for some reason. Where would I order a replacement and what type of place could fix it? It should be very easy but I'm not the handiest of guys.
Picture attached.
mrpettit is offline   Reply With Quote
Old 06-10-2015, 01:33 PM   #2
Fort Worth , Texas
Here is the image of the broken hook:
Old 06-10-2015, 01:50 PM   #3
LongShot's Avatar
2015 19' Flying Cloud
Ashland , Kentucky
Images: 8
Why don't you just drill out that rivet, then drill another hole the the side and re-attach it to the support rod. This would get you back in the game for now until you could secure a replacement from the Zip Dee folks. You'll need Part#718611 - SATIN CLAW AND BAR ASSEMBLY WITH PIN. Follow this link to ZipDee Parts
One Long Shot
Beastie - 19'FC
The Big Beast - GMC Yukon w/Max Tow Package
Held together with the Husky Centerline Hitch
LongShot is offline   Reply With Quote
Old 06-11-2015, 05:03 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would call ZipDee.. get a couple of those.. It looks like it cracked through the hole where the previous rivet was. When you install the new one, open up the hole a bit ...
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-11-2015, 05:14 AM   #5
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Take the arm off the trailer and take it to an Airstream repair facility to replace the claw if you are not handy. Or order a new claw and replace it yourself if you are, it's not difficult.
One of the reasons they can break is the arms stick when sliding to put the awning up. Always keep the arms well lubricated with silicone.
cheryl
ckottum is offline   Reply With Quote
Old 06-11-2015, 05:47 AM   #6
dznf0g's Avatar
Oswego , Illinois
Someone said, on another thread, that if you ask they will give you new storage position posts for the rafter arms. Most apparently break because we don't get the throat of the hook into the smaller diameter area of the post. If it is in the larger diameter position it puts undue strain on the hook and cracks it.
-Rich-
Old 06-11-2015, 05:50 AM   #7
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If you are moving, DucTape. Had it happen in Northern Maine. Finished lowering and taped the two arms together. Went on our way for another almost 3,000 miles before I could get it fixed with a new part. Held fine, but could not use the awning.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-11-2015, 07:22 AM   #8
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
We had the same thing happen earlier this year. I mentioned it to another AS owner, as I was taping it back together. About an hour later, he came over and mentioned his was cracked too. I have a replacement from Zip Dee, but the tape job is still going strong.
Old 06-11-2015, 12:45 PM   #9
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
Call Zip Dee....they sent me a new one for free. It's very easy to replace.
smlbob is offline   Reply With Quote
Old 06-11-2015, 01:40 PM   #10
2015 25' FB International
Toano , Virginia
It's called a claw. Zip Dee has them in stock. I called them and they sent me 2, now I have a spare. However, they weren't free!!
StreamTime is offline   Reply With Quote
Old 06-11-2015, 02:21 PM   #11
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
that must be a weak part. When we were going on our walk thru while picking up our 2015, the piece broke just like that when the tech was demonstrating how to operate the awning.
1Boyscout is offline   Reply With Quote
Old 06-11-2015, 02:49 PM   #12
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Not free for me either. Somewhere in the $25 range. I guess I should get off my duff and install it. BTW, they sent another storage post.
Old 06-11-2015, 03:05 PM   #13
dznf0g's Avatar
Oswego , Illinois
See post #6
-Rich-
Old 06-11-2015, 03:06 PM   #14
dznf0g's Avatar
Oswego , Illinois
See post #6. Starting to smell me now?
-Rich-
Zip Dee Support Arm Air Staked to Ground Bambi_Bandit Awnings 21 08-19-2011 03:23 PM
Zip Dee - Center support or not? vhord Awnings 42 07-01-2010 07:57 AM
Zip Dee awning pull strap broke ? Davis Awnings 13 12-26-2009 04:57 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
