Old 06-11-2015, 06:29 PM   #15
2015 19' Flying Cloud
Santa Clara , Utah
Zip Dee claw
Contact Zip Dee or order through AS parts store or another RV shop if AS isn't near by, less than $30 including freight
ByHyway is offline   Reply With Quote
Old 06-11-2015, 06:54 PM   #16
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
This is a very easy fix. So being handy if not is not so issue.
Breaking claws is a known problem and is directly connected to the placement of the claw on the storage post. Zip Dee will send you replacement posts that are larger and will solve the is placement issue. There is no charge for the posts if you call them at customer service. They will want to know the year of your trailer as 2007 and newer units only need the posts but 2006 and older need the posts and a set of longer bolts
Hope this helps
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-11-2015, 07:22 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
When setting up the awning, remove the claw from the storage post, then attach it to the roller bar after the awning is unrolled.
When putting the awning away, first detach the "claw" from the roller bar, push it in and set it over the storage pin, then roll the awning back.
I have never broken a "claw".
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-11-2015, 08:42 PM   #18
2014 27' Flying Cloud
Willow street , Pennsylvania
Zip Dee hook
This is undoubtedly a design flaw, because this cast aluminum part breaks frequently. We had it happen just after we started using the awning, no wind, undo force, or any reason I can put my finger on. Airstream dealers keep a supply handy because it happens so often. Just take the arm (slides out of the sleeve easily) and the broken hook to a dealer and they will put a new one on for free and you're on your way.
Rgmhog1450 is offline   Reply With Quote
Old 06-11-2015, 08:52 PM   #19
dougandlori's Avatar
2004 28' Classic
Fresno , California
Good to know about contacting direct to zip dee. I lost one in arizona over the winter. Contacted one of the usual suppliers and ordered two. These posts confirm poor quality or a design flaw.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 06-11-2015, 08:58 PM   #20
Binghamton, New York , New York
You can purchase a stainless steel hook from almost any Marine Store - they've got about fifty different kinds that would work just fine. Last forever, as well. The hook is just insurance and the stainless would look better.
Pursuit 97 is offline   Reply With Quote
Old 06-11-2015, 10:06 PM   #21
1994 30' Excella
Mississauga , Ontario
As said before, it happens when you park the claw on the wrong part of the post before putting the awning away. Then when you roll up the awning it gets trapped and the force of those long arms snap it. I know, I have done it. When ZipDee explained how it happened it was obvious. And for those who say it is a design flaw, be happy that only the claw breaks. If it didn't you would very likely bend the main arm.
Al
Al and Jean
TAC ON-3
Old 06-12-2015, 08:13 AM   #22
2007 19' Bambi
Park City , Utah
I just had to replace my claw. I ordered it from airstreamsupply.com in SLC. It was easy to install. I used a little baling wire to tie the arm to the support while we drove home.
Chucke is offline   Reply With Quote
Old 06-12-2015, 09:14 AM   #23
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I used zip ties to hold mine in place when my claw broke. I think some guys use zip ties whenever they are traveling, as a precaution that the rafter arm does not come loose and cause damage to the airstream skin, like a bolt coming off.
Hiho Silver is offline   Reply With Quote
Old 06-12-2015, 09:47 AM   #24
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I use those reusable rubber coated twist wires.
SteveSueMac is online now   Reply With Quote
Old 06-15-2015, 07:04 AM   #25
2013 23' International
foster , Kentucky
Talking Zip Dee
We had this happen on our last trip. In one of the other threads they had said to always have electric tape (vs. duct tape) because it is waterproof and better in holding all objects ...so we used electrical tape to hold it in place while we traveled home. We called Zip Dee. They were very helpful. My husband also surfed the web ...there were other places that sold you just the claw but it looked like a pain to install ...Zip Dee sent us the whole piece assembled. Took my husband less than a minute to replace. Also, the guy sent us two items (one for each arm of the awning) that prevents this from happening ...those were free ...the Zip Dee was $19,95 and the shipping was $7.95. Personally I am more comfortable with the original company's part. Besides they paid for all the research and patents etc. But that is just me.
kfthomas is offline   Reply With Quote
Old 05-28-2016, 10:58 AM   #26
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
I have had two break on me. Must be a weak design.
DuncanK1 is offline   Reply With Quote
Old 05-28-2016, 12:01 PM   #27
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Al
Right! This can happen when the claw hook is placed on the larger section of the step spacer pin. The claw must be placed on the narrower section!
This can easily happen, even if you have used your awning without incident for years. All it takes is to be distracted, in a hurry, or in poor light conditions.
Additional info: "Broken claw casting on awning"
Below is a photo of my claw hook properly placed on the step spacer pin.
Name:	DSC_0050 claw on step spacer pin.jpg
SilverGate is offline   Reply With Quote
Old 05-28-2016, 12:18 PM   #28
SilverGate's Avatar
2007 23' Safari SE
Zip Dee awning parts can easily be replaced... and ordered through Zip Dee.
See their parts page: Zip Dee Parts List
Additional info on Zip Dee: "An All-American Stop: Zip Dee"
Zip Dee Support Arm Air Staked to Ground Bambi_Bandit Awnings 21 08-19-2011 03:23 PM
Zip Dee - Center support or not? vhord Awnings 42 07-01-2010 07:57 AM
Zip Dee awning pull strap broke ? Davis Awnings 13 12-26-2009 04:57 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
