Old 05-18-2006, 04:30 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Zip Dee roller plate please help with a picture
Can someone please take a picture and post it here on how a Zip Dee roller plate is supposed to be installed on the middle portion of the lengthwise awning for a 1979 (or other) 31' rig? I called Zip Dee because I could never figure out just where the middle support for the awning was supposed to go. Couldn't find a spot where the pointed end of that support would plug into. We came to the conclusion that I was missing the "roller plate" on the middle of my awning. Now have roller plate in hand but a picture would be worth a thousand words as to where it is supposed to go.
wacnstac is offline   Reply With Quote
Old 05-18-2006, 06:39 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
awning plate
hey wac,
i did not forget about you!
here are some pictures of my awning, hope it helps!
john
ID:	21468   Click image for larger version
you call them ferrets, i call them weasels.
Old 05-18-2006, 06:40 PM   #3
The center support must be attached to a vertical rib.
The roller tube end of the center support plugs into a plate. The center of that plate is a guide for you to drill a hole through the plate and through the roller tube.
Doesn't matter that the center support may not be exactly in the center of the roller tube.
That's it.
Old 05-18-2006, 06:43 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
looks like we posted about a couple of seconds apart andy, thanks for the tip!
john
Old 05-18-2006, 06:46 PM   #5
Images: 43
Well I'm missing that plate completely but have a new one from Zip Dee now. Hopefully with the help given here I can find where the old one may have fallen off.
Old 05-18-2006, 06:49 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
wac
if you unroll your awning all the way you might be able to feel where the holes are in the tube.
john
Old 05-18-2006, 06:57 PM   #7
Images: 43
Hmmm, something don't seem right here. Here is a picture of the L bracket (which looks about right) and the roller bracket.
Does it look like the roller bracket is even big enough to support a hole large enough for the pole?
http://www.airforums.com/photo...iginal=1&c=504
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Attaching a single picture to your post PeterH-Airstreamer Forum Admin, News and Member Account Info 62 12-04-2004 10:44 PM
Picture of Radio? Pick General Interior Topics 1 10-12-2002 06:57 AM
Help with picture Lexxy Our Community 8 08-20-2002 07:24 PM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
