Old 08-08-2010, 08:54 AM   #1
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
Zip Dee Rivets
I am trying to get all the leaks fixed on the Airstream. I found one of the brackets that hold the Street side awning loose. Does anyone know what kind of Rivets these are? Will screws hold if I drill them out? What size screw. The Rivet looks like it is split into three parts on the back side. Not a regular blind rivet.
Thanks for any help offered.
ID:	108322   Click image for larger version
_____________________________________________
"I love work, I can sit and watch it for hours."
Al
Archersfin is offline   Reply With Quote
Old 08-08-2010, 11:23 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Don`t know what that rivet is,if you google Zip Dee,they may have them for sale. Dave
easyride is offline   Reply With Quote
Old 11-16-2019, 11:29 AM   #3
1977 31' Excella 500
Eustis , Florida
3/16 3/4 Olympic rivets. You can order them directly through zip dee by calling their customer service.
TinCan Sojo is offline   Reply With Quote
Old 11-16-2019, 11:33 AM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
3/16 Olympic rivets. I have bought them at ODM & Zipdee.
3/16 holes are already too big for screws.
Alan
Old 11-17-2019, 06:41 AM   #5
1990 29' Excella
baltimore , Maryland
I just came to the forum to post the same question. Lol
I asked this question several months ago and was told to go buy the olympic rivets.
You can only get a $25-30 bag of 100 which i bought.
They are way too small. The rivets on the zip dee must be much larger.
Hopefully the correct answer?
groundhogy is offline   Reply With Quote
Old 11-17-2019, 07:13 AM   #6
A W Warn's Avatar
2000 25' Safari
I think you received the wrong size rivet.
Look at this>
http://odmrv.com/catalog/index.php?m...roducts_id=376
ps:
Maybe you got the 5/32" rivets, which is a lot smaller, the size used for connecting aluminum skin to ribs.
Like these>
http://odmrv.com/catalog/index.php?m...roducts_id=377
Alan
Old 11-17-2019, 08:29 AM   #7
1976 31' Sovereign
Oswego , Illinois
When zip-dee installed awning on my AS the rivets used on arms such as shown in post #1 IMO are not olympics but a larger size of pop type [pull thru rivets] the rivets used can not be shaved as olympics are also they have fairly large size hole & a ridge around hole and not domed on top as olympics do not have these features of rivets shown. I have used many olympics and own a shaver.
Old 11-17-2019, 09:12 AM   #8
1986 25' Sovereign
Allegan , Michigan
My brackets were originally held on by sheet metal screws. I replaced them with oval head(?) machine screws and threaded inserts. The threaded inserts are like a "blind rivet" that goes into an oversize hole in the sheet metal shell. A handy way to use removable screws instead of rivets - future repairs are easy.
I think I got mine from McMaster Carr. They come in a number of variations including material and sheet metal thickness. I might be able to check and get more information if that would be helpful.
whit Nash
rwnash is offline   Reply With Quote
Old 11-17-2019, 01:53 PM   #9
A W Warn's Avatar
2000 25' Safari
This is a link to a parts list for a ZipDee awning. Check out item #15 on the list.
http://nebula.wsimg.com/58bea69f88a0...&alloworigin=1
Alan
Old 11-17-2019, 02:05 PM   #10
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
There appear to be a couple of possible correct rivets. Can't wait to hear what actually worked in this case.
brad1 is offline   Reply With Quote
Old 11-17-2019, 03:39 PM   #11
1990 29' Excella
This is what I see when I pull off the zip dee fittings that sit right on the exterior skin of the airstream.
When looking into the holes that the awning has to be mounted into, I get scared.
So say there are three holes in a row where your mounting hardware (rivet or something) is supposed to go. When mounting the awning, they do aim for the structural aluminum beam that sits below the surface of the aluminum skin, but like only 1 or 1 1/2 of the 3 mounting hardwares actually bed securely into this beam. The others are clinging to the aluminum foil.
Also, the depth of the rivet needed, will be very deep.
The awning fixtures that mount to the outside of the airstream are pretty thick.
I don't have them in front of me, but they could be 0.5 inches. So the rivet has to pass through this material, then also pass well through the aluminum beam material inside the airstream skin.... and THEN the head has to expand and flatten out.
RWnash.... I would love to hear about your solution with the McMaster Carr parts.
Sounds very interesting.
Airstream should be putting backing plates behind were they intend the awning to go. I am ashamed for them.
Of course on the other hand, maybe they actually made an engineering decision to not put a backing plate in.
If you get the 50 mph wind gust with the awning out.... maybe you want it to more easily fly away rather than pull out a 1x1 square foot piece of wall out with it.
Old 11-18-2019, 09:38 AM   #12
1976 31' Sovereign
Oswego , Illinois
Question
This link comes up domain for sale, nothing about zip-dee parts list?
Old 11-18-2019, 10:34 AM   #13
1981 31' Excella II
New Market , Alabama
Some of mine have been replace with sheet metal screws which is not good either. I wish I had put some 1/4-20 screws in mine with Nyloc nuts when I had the skins off. Lots of stress on this area. Another reason not to leave the awning up in the wind.
Perry
Old 11-18-2019, 10:42 AM   #14
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I just get a blank page.
thewarden is offline   Reply With Quote
Old 11-18-2019, 05:23 PM   #15
A W Warn's Avatar
2000 25' Safari
The link works for me. I tried it in both Chrome and MS Explorer browsers.
You can find the information at >
http://www.awningsbyzipdee.com/parts-lists.html
Then click on the part list for Contour hardware, select the one for the year model of Airstream that you want to look at.
On both Contour schematic drawings, part #15 (pre 1989) or part #18 (1989 & after) is a 3/16" "Olympic" rivet.
ps:
Note these are ZipDee's instruction. Airstream may or may not follow those instructions.
Alan
Old 11-19-2019, 08:28 AM   #16
1986 25' Sovereign
Allegan , Michigan
I did a little checking. It turned out that I used 1/4 - 20 pan head stainless steel screws and aluminum rivet nuts. (McMaster Carr lists rivet nuts as a "sub class" under "threaded inserts.") I think these are what I used:
https://www.mcmaster.com/94020a343
Other vendors such as MSC have similar items.
It has been a while since the repair; what is leftover in my parts bin may not be exactly what I used. However, "twist resistant" aluminum rivet nuts are what you need - with the appropriate grip range.
I have a couple of thread repair kits from AVK Industrial Products. The ones with the larger flange are referred to as "AL inserts." (AL refers to the style and not the material.
As I said above, this repair can be undone with ease for caulking. But, it might cause more damage in an accident. ( An orange traffic barrel committed suicide by running into the side of the trailer in a construction zone. The original sheet metal screws simply pulled out. I might have been able to use larger screws but the rivet nuts seemed like a better solution.)
Let me know if I can be of further help.
Whit Nash
Old 03-28-2020, 09:46 PM   #17
cloud camper's Avatar
2013 25' Flying Cloud
Lacombe , Alberta
This is the most useful thread I've found yet - I have the exact same problem to fix on my FC 25. (after removing the top bracket for awning rafter arm) - I have three larger holes in the skin where the aluminum metal screws were that held the curved clamp assembly, now removed and plugged with silicone seal until repairs. I'll be phoning McMaster Carr for sure. Thanks very much
cloud camper is offline   Reply With Quote
Old 03-29-2020, 08:37 AM   #18
1986 25' Sovereign
Allegan , Michigan
Cloud,
You might want to spend some time on the McMaster Carr web site. It is probably the best one around for hardware type items. Depending on how you search, a number of similar items will show up. Reading the descriptions can be a real education. Once you find an item, I think you can go to its catalog page and browse. (McMaster Carr still has a massive 4000 page catalog, or at least it used to. I have a couple of out of date ones I still use for reference.)
You might also try MSC, lots of stuff but I am not as handy with their search function.
Good luck
Whit Nash
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee shinola345 Awnings 3 07-19-2006 10:51 AM
Zip Dee Inland RV Center, In Commercial Listings 1 07-13-2006 03:31 PM
Zip Dee Awning rivets Rob30044 Awnings 4 03-30-2006 02:52 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
