Old 07-18-2007, 11:50 AM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
Zip Dee retrofit
Does anyone know the difference in the zip dee awnings of the pre-'69 era and the '69 -thru- 70's eras?
I'm trying to determine what I'll have to modify (if anything) to fit a mid-70's AS zip dee to a '64 AS
the zip dee co. only knew that they listed them as different models.
thanks.
Doug
59er is offline   Reply With Quote
Old 07-18-2007, 12:54 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Wow, I'm surprised Zip Dee couldn't answer that question. I'd try talking to someone else.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-18-2007, 01:08 PM   #3
1990 34' Excella
Parsonsfield, , Maine
thanks.
There was an awning man at the Travelers Rest Airstream Park in Dade City, Florida who previously worked for the Zip Dee Co. His name was Bill Phoenix. His home was in Orlando. Don't know if he is still alive or not, but he dates back pretty far and probably could answer your question. I don't think Bill is working on awnings at Travelers Rest any more but someone there may have his phone number. Travelers Rest advertises every month in the Blue Baret where you can get their phone number. Good luck. Charlie E. WBCCI 1128
CharlieE is offline   Reply With Quote
Old 07-18-2007, 01:41 PM   #4
thanks.
The awning is the same for both years, but the length may be different.
However, the arms are completely different. You can buy just an arm set if you wish.
Old 07-18-2007, 02:00 PM   #5
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
are the arms from the newer (69-??) coaches longer or ???
the bends/angles appear to be similar but the awnings look like they might be mounted higher to get them up above the vista views...
Doug
Old 07-18-2007, 02:05 PM   #6
The shell shapes are different and the awning rails are in different places as well.
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
Retrofit Grey water tanks smily Waste Systems, Tanks & Totes 10 02-01-2003 12:17 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
