Old 08-05-2003, 09:57 AM   #1
montanaandy's Avatar
Zip Dee Repair
I have a large white & blue striped Zip Dee awning that needs repair. I was cleaning the awning/drying it out when it was hit with a micro burst of wind. The awning fabric split down the middle (north to south) along the seam. It appears that it just needs to be sewn back together along the seam(everything else appears to be all right). Any suggestions as to who/where I might have this work done? Thanks,
Montanaandy
montanaandy is offline   Reply With Quote
Old 08-05-2003, 06:17 PM   #2
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I would look for a truck tarp shop first and then a boat cover shop next in the yellow pages. They are typically small business men but, with a commercial sewing machine, they should be able to do the job.
I have never removed an awning. Understand it can be a pain.
Goodluck
wingfoot321 is offline   Reply With Quote
Old 08-06-2003, 12:21 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Actually, it's
montanaandy &
wingfoot
The awning is actually not that hard to work on..Armed with a few simple tools and, a drill and a pop rivet gun is about all you need to work on it.
The biggest challenge is the "charging" of the awning's spring after you've completed the work.
It's rather surprising but, the internal works are the same for all sizes except for the number of turns you use to charge the spring.
Just be careful in doing this one aspect of the operation because, if it gets away from you...you could get hurt...
ADJUSTING TENSION OF PATIO AWNING SPRING
Zip Dee website
Other great info is found under this thread and, the people at Zip Dee are top drawer to work with as well~!!
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Zip Dee repair question Tin Hut Awnings 5 01-10-2004 11:34 AM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
Adding Zip Dee awnings on other windows... drboyd Awnings 1 09-28-2003 10:08 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
