Old 08-11-2018, 10:17 PM   #1
2019 27' Globetrotter
Houston , Texas
Zip Dee “Relax” Power Awning FIXED
We picked-up our 2019 Globetrotter on Thursday in Baton Rouge. The dealer demonstrated the power awning; no hint of trouble. Back home in Houston on Friday night we tried the awning: NUTHIN’. No lights at all on the control board.
We were fixin’ to call Zip Dee and Airstream on Monday, but in the meantime the dealer sent excellent schematics of the whole trailer (much more detailed than the User Manual).
On a random Airstream owner’s website (trailandhitch.com) I found that the Zip Dee control circuit board is located “under the sink”. On the Globetrotter, the only place than could be is OUTBOARD of the wastebasket compartment.
Found a thin white laminate cover secured by two Phillips screws; removed it and discovered the Zip Dee control board laying in the bottom of the cavity underneath.
Apparently, the board is supposed to be secured in the compartment with a couple of strips of double-sided foam tape. I’m guessing that that idea didn’t survive the Summer heat in Baton Rouge. Gonna need a new idea, maybe a little shelf and a bungee cord?
I pulled the board up and out of the aft hole in the countertop, still attached to its wires. If you’ve ever see a Caesarian Section (don’t ask), it was like that.
I quickly noticed a green receptacle on the board labeled +12v/-12vdc, with NO PLUG IN IT. Scrounged around in the bottom of the cavity and found the matching green plug. Presumably, the plug got knocked out of the receptacle when the board fell to the bottom of the cavity. See photo; the green plug/receptacle is at 4:00 o’clock.
When I plugged it in, the LEDs on the board lit-up and the CLOSE LED on the switch panel lit-up too. Ran the awning out about half-way, stopped, then closed it all the way. It’s late, so I’ll button it up tomorrow.
Easy fix that never should have been required. Hope this helps somebody down the road...
Hareynolds is offline   Reply With Quote
Old 08-11-2018, 11:45 PM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Thanks, That should save someone a bunch of grief .
I wonder if there are any more hidden control boards for other stuff and where they are .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-12-2018, 04:36 AM   #3
Acheron2010's Avatar
2018 26' Flying Cloud
Morristown , Tennessee
Excellent post illustrating the capability of an owner to fix problems. Congrats.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
Acheron2010 is offline   Reply With Quote
Old 08-12-2018, 12:37 PM   #4
Houston , Texas
Thanks for the nice comments; just trying to pay-back a tiny fraction of the help that the Forum has provided me over the last couple of years.
Here's the "fix" I employed (sorry, forgot to take pictures):
(a) cut a 5" x 8" piece of scrap 3/4" baltic birch ply
(b) cut a 5" x 8" piece of ~1/4" closed cell foam (like a mouse pad).
[note: I have tons of stuff like that squirreled-away in my shop. Your squirreliness may vary.]
(c) screwed the circuit board (with foam underneath) to the plywood with small pan-head screws, one each top and bottom. Tighten screws just enough to compress the foam a bit.
(d) apply 2" 3M double-sided tape to back of plywood. Test-fit with the tape still covered. Uncover the tape and ROCK the plywood into place from the top edge.
Note that I applied about 5x the tape area that was originally on the circuit board. It isn't going anywhere.
The circuit board can now be removed with a stubby Phillips head screwdriver (or more to the point, a swiss army knife) without prying-off foam tape.
Elapsed time was maybe 30 minutes, including sanding the scrap plywood.
Who has a Zip Dee Relax 12v Automatic Awning? veg hed Awnings 47 Yesterday 08:04 AM
Zip Dee Relax Awning Problem CEG Awnings 6 07-28-2018 07:29 AM
Zip Dee Relax Awning Dennawayne General Repair Forum 9 07-08-2018 08:40 AM
Zip Dee Relax Power Awning ksteve06 2016 - Current International 3 06-06-2017 12:51 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
