Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 12-23-2010, 04:41 PM   #1
1973 Argosy 26
Anniston , Alabama
Zip Dee question
Once again, I appreciate this HUGE source of information! I'm completely renovating a '73 Argosy 26', will be adding a ZD awning, and am installing the brackets in the positions left by the PO (which leaked). I'll strenghthen and leakproof the backing plates while interior walls are off. Got to thinking, with my former camper, and once the awning was deployed (neither an Argosy/AS nor a ZD), I enjoyed being able to remove the support arms from the bases so as not to have a 45 degree obstacle fore and aft. Will this work with a ZD? I'm thinking a pull pin in the lower bracket instead of a bolt, and maybe purchase a set of lower brackets to use as feet for the support arms, and then position them vertically and stake. I just want to find out from the vast experience here if the ZD geometry will allow this. (BTW, I will be posting pics as I can.)
Thanks much, Phil
prob is offline   Reply With Quote
Old 12-23-2010, 05:05 PM   #2
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Zip Dee awnings are the finest made (I am not a rep),one learns to paying attention when they are deployed. We've hung warning tape, towels, etc. over the arms and STILL bumped into them! After 20 years of Zip Dee awnings, we've finally got used to the arms, until tomorrow, before I've had my second cup of coffee!
Mike Leary is offline   Reply With Quote
Old 12-23-2010, 05:15 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
There are provisions available from ZD to remove the main arms and anchor them, the same as other brands.
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 12-23-2010, 05:18 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Yes you can move the support arms out to the ground as you mentioned. Another poster has some pics of a bracket he made that he uses on the ground that the arms attach to with pins as you mentioned. Search around in the forum and you may find the post. I have lowered mine to the ground and really enjoyed them in that position. Zip Dee is the best.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-23-2010, 06:17 PM   #5
1973 Argosy 26
Anniston , Alabama
Thanks to everyone for super quick responses. Hope you all have a wonderful Christmas!
Another Zip Dee Question--just a quick one! Becky B. Awnings 11 07-12-2010 08:36 PM
Zip Dee chairs question? wantostream General Interior Topics 16 09-24-2008 09:25 PM
zip-dee awning question goransons Awnings 9 11-23-2007 10:39 AM
Question about zip dee install loechli Awnings 3 08-05-2006 07:16 AM
Zip Dee repair question Tin Hut Awnings 5 01-10-2004 11:34 AM
