Originally Posted by Fishbone
Greg,
The fabric on the one I'm looking at is shot. Can the roller be cut to size to fit my coach.
Where did you find the AS3 information?
Yes, you can cut the roller tube. It's safer to cut the end, that is closest to the front of the trailer. In that way, you won't mess with the spring, which is on the rear half.
Knowledge of Zip Dee's products, as Greg does, makes it easy to know which arm set to use for which year Airstream.
Replacing the fabric, must be done with extreme precision, so that the fabric will roll up correctly. If not, the fabric will coil up towards the front or rear of the tube.
That's why Zip Dee sells the fabric and roller tube, already assembled. Saves the trouble of installing the fabric.
