Old 12-27-2008, 05:52 PM   #1
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Zip Dee mounting rail to rear cap
Just wondering if anyone has seen this issue before. I searched the threads and did not see another post. My rear awning is coming detached from the rear of the trailer. It looks as if the rail is straight and the cap bends around and either it was stuck there with double sided tape and come lose or this is the way it is?
Name:	Slide out alignment 009.jpg
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 12-27-2008, 06:30 PM   #2
The rear window awning rail was not installed correctly.
Add a couple or so of olympic rivets at each end and it will be fine.
Old 12-27-2008, 06:36 PM   #3
moderator
Airslide's Avatar
Wilton , California
Images: 50
Oh man.. Thats what we thought. Drill into the exterior .. yikes.
before i do that, could it be the wrong awning for the trailer? could there be a shorter mounting strip?
Old 12-27-2008, 09:38 PM   #4
The correct rear window awning is called an 047, meaning 47 inches wide.
Old 12-29-2008, 11:45 AM   #5
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
What a surprise I came in to look into rear awnings and the first thing I see is about rear awnings it is just to cool. I am getting ready to put on the new Zip Dee and looking at it I think I have to move the rear lights up a little to make a little more room. Has anyone put one on a 1970 31' airstream? I should have looked a little better at the rallys. And by the way mine came from Zee Dee with olympic rivets and they say to use them just like Andy said. Dave
geezernbabe is offline   Reply With Quote
Old 12-29-2008, 12:32 PM   #6
The rear clearance lights, are ok where they are.
It will be a little tight, but you don't need to move them.
Old 12-29-2008, 12:55 PM   #7
1970 31' Sovereign
Thanks Andy that made my day. Dave
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee Inland RV Center, In Commercial Listings 0 08-27-2007 10:06 AM
Zip Dee shinola345 Awnings 3 07-19-2006 10:51 AM
Zip Dee Inland RV Center, In Commercial Listings 1 07-13-2006 03:31 PM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 05:35 PM
