Old 05-07-2019, 02:22 AM   #1
2015 30' Flying Cloud
Vancouver Island , British Columbia
Zip Dee manual awning help
Iím having problems with deploying the awning with the rod that connects to the wheel. The rod is wobbly and makes it difficult to manipulate. The rod was supplied by airstream. Anyone has a fix for that ?
rintintin is offline   Reply With Quote
Old 05-07-2019, 04:20 AM   #2
dznf0g's Avatar
Oswego , Illinois
Yeah, throw it away or repurpose it. I use a step stool and hand tighten. The rod doesn't get it tight enough anyway
-Rich-
Old 05-07-2019, 04:24 AM   #3
2019 30' International
Pennsylvania , Pennsylvania
When I had the manual awning, I gave up on the rod. I carried a little ladder and stepped up on that to twist the rear one open and closed. I could reach the front one by standing on the step.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-07-2019, 04:37 AM   #4
Long Island , New York
The wheel manual system works fine if you:
— lube threads and bottom of wheel where it mates with the receiver; and
only pull on the rod, don’t ever push.
Yes, this requires re-positioning the rod more often. What’s the rush?
Take your time, jiggle the awning arms once in a while to get the wheel to seat wheel good!
No prob!
Peter
Old 05-07-2019, 05:33 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....👍
X2
Pull don't push. Left side of the wheel to loosen, right side to tighten. Keep the treads clean and lube with spray PTFE.
On the support arms...make sure they plumb. The rear arm on our Classic had to be moved forward to get the awning to roll & lock properly.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 05-07-2019, 12:23 PM   #6
Annapolis , Maryland
My technique is:
Use the rod to unlatch the Z lock and one wheel lock, pulling, rather than pushing the wheel;
Open the other wheel by hand while standing in the doorway,
Insert the rod into the awning loop at the center point of the roll.
Pull the awning loop to launch the awning.
The rod works fine for this.
Closing is the same, although I use a piece of line through the loop instead of the rod, just to ensure that the loop stands proud of the furled awning, ready for the next launch.
rhpeahl is offline   Reply With Quote
Old 05-07-2019, 11:33 PM   #7
Thanks everyone
Manual Zip Dee Awning question Driftin Di Awnings 12 05-18-2017 03:58 PM
Need immediate help with Zip Dee awning cfishii General Repair Forum 6 07-14-2015 08:53 AM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
